headlight problem |
headlight problem |
Feb 16, 2004 - 12:40 AM |
Enthusiast Joined Aug 13, '03 From Greencastle, PA Currently Offline Reputation: 0 (0%) |
Hey guys I was wondering if someone could help me out here. I rewired my foglights today, (aftermarket) and wired them into the headlights. I disconnected the low beams and brought the positive from the foglights up and matched it to the headlights. I turned my lights on and everything was working fine (low beams and fogs). Then I turned the high beams on and the entire passenger side went lights went out, but the driver side was fine. Then after turning the highs off my driver side low was fine but the passenger side high and low were both still on. Could this possibly be because there is not enough power to run the fogs along with everything else? Thanks
Feb 16, 2004 - 12:41 AM |
Enthusiast Joined Aug 30, '02 From Ohio Currently Offline Reputation: 0 (0%) |
Should have run them to the running lights in your turnsignals or the fender lights.
-------------------- Jared Harwell
Feb 16, 2004 - 12:48 AM |
thanks phat. I'll check that in the morning and see what happens.
Feb 16, 2004 - 5:23 AM |
Enthusiast Joined Nov 4, '02 From Hecho en la Republica Dominicana/Living in NJ Currently Offline Reputation: 0 (0%) |
check i'm not sure about the celi cause i haven't done it yet.. but most toyotas.. have the extra outlet from the fuse box were you hook up the foglights from... thats were you should hook your fog lights from...
Feb 16, 2004 - 9:00 AM |
thanks macavely. i never thought of doing that. I had them hooked up with my own switch til the switch broke I'll look at it today after class and let you guys know.
Feb 16, 2004 - 3:27 PM |
Enthusiast Joined Oct 1, '02 From Minnesota, USA Currently Offline Reputation: 0 (0%) |
Yehp, that should solve your problem. Excellent diagnosis Dr. Macavely.
-------------------- 95 Toyota Celica GT
Dead for now --> Soon to have a 3S-GTE 02 WRX --> This is for speed - Borla Exhaust - TurboXS BOV - Custom CAI 02 Civic EX - MB Quart Reference 5.25" Components - Rockford MTX 8" Subs in the doors - Alpine Type S Rear Fills - 2x Alpine SWR-1042D Subs in a custom fiberglass box - Alpine F345 Amp for the front doors - Alpine M605 on each Type R - Phoenix Gold wiring - Alpine CDA-9855 Head Unit - Alpine Amp link - 2x Rockford Fosgate 1 Farad Caps - The best Viper 791 alarm install ever |
Feb 16, 2004 - 3:29 PM |
the foglight fuse is located in your dash correct? Where is the output of that fuse located?
Feb 16, 2004 - 8:53 PM |
alright guys thanks for all your help, i ended up wiring them into the side markers and everything is alright. I had a blown fuse which was screwing up the headlights
Feb 16, 2004 - 11:56 PM |
there should be 2 fuse for the foglights one under the dash and one under the hood.. -------------------- |
Lo-Fi Version | Time is now: December 4th, 2024 - 5:18 AM |
