> Gas problem
post Aug 19, 2015 - 8:33 AM
Naxx
Joined Aug 16, '15
From Norway
Hey, i have a problem with my car, when i stopp pressing the gas my car starts humping? Anyone know what is wrong?
Sorry bad english.
Thanks
Replies (1 - 3)
post Aug 19, 2015 - 9:56 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Has this problem gone on for a while? Or newly started?
I've noticed that the GT manual is very tricky, if you let off the gas too abruptly, it will jerk or "hump" forward and back a couple times.
But if you let off the gas smoothly, it doesn't cause this issue.
Not sure if this is what you're talking about or not though.
My Celica!
post Aug 19, 2015 - 10:39 AM
Box
Joined Feb 23, '12
From Warrior, AL
Sounds like you're lugging the motor. Should take it to about 2,500-3,000 before going into the next gear until you hit the speed limit and you can go straight to fifth. Coming to a stop unless you're needing engine braking just put it into neutral and use the brakes to bring it to a stop. Should eliminate any lugging.
2001 Miata LS 5-speed
post Aug 21, 2015 - 12:40 PM
Naxx
Joined Aug 16, '15
From Norway
Tanks it works just bougth car tongue.gif thanks alot guys
Lo-Fi Version Time is now: February 21st, 2025 - 10:21 AM
