Help! Clutch problem. |
Feb 22, 2016 - 2:25 PM |
Enthusiast Joined Jan 24, '16 From Memphis Currently Offline Reputation: 0 (0%) |
Im new here so i dont know if this is aleeady a topic. But my slave cylinder went out a few days ago, and i replaced it. We bled it and it didnt fix the problem. But we went back and pried the boot or whatever and got more pressure and it works okay now. In the process we heard a pop noise and the clutch worked fine for a day or two and out of nowhere im leaving my works parking lot in 2nd (no stopping) and the clutch stuck and took off without me pressing the gas. I noticed the pedal slowly rise back up and it shifted fine after that. Then in walmart parking lot it happened again in 2nd and i threw it and neutral and managed to pump the pedal back up. So i feel like there is a pressure problem. Praying that i dont have to take out the tranny. The cap for the reservoir had fluid come out at one point so im hoping its just that allowing air into it. But so far all i know to do is pump the clutch in neutral before i shift now...
So yeah i have a new slave cylinder. About to get a new reservoir cap. My dad thinks its the throwout bearing. I need some things to look at before i spend a day and potentially a chunk of money on a new clutch please help. 96 celica st204 i think. |
Feb 23, 2016 - 9:54 AM |
throw out bearing wouldn't cause that.
you might need to rebuild the master cylinder. -------------------- 2001 Celica GT-S Turbo
Feb 23, 2016 - 10:43 AM |
Enthusiast Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
Definitely sounds like the master is shot. Easy fix!
Feb 23, 2016 - 11:55 AM |
Enthusiast Joined Jan 30, '14 From Cortland NY Currently Offline Reputation: 5 (100%) |
Definitely sounds like the master is shot. Easy fix! Second that, simple fix -------------------- 1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool. |
Feb 23, 2016 - 2:14 PM |
Lo-Fi Version | Time is now: November 27th, 2024 - 10:12 AM |
