> Factory Plug Wires, The end of the boot always gets stuck down in the plug tube
post Feb 28, 2016 - 11:55 AM
VavAlephVav
Joined Dec 3, '13
From Missourah
With cheap wire sets the rubber end at plug connection tends to slip off and end up stuck to the spark plug all the way down inside the spark plug tube.
Then I have to dig it out with my hook and pic set and the rubber is all torn up and a tiny chunk of it ends up down in the cylinder...
Even the Denso brand wire set I got on Rockauto isn't high quality. But I called Toyota and they want $116.00 for a set of wires!
However I'm willing to pay that as long as I know I'm not going to have to deal with sheaht like this.
Can anybody confirm that the factory wire set is made better?
I'm hoping that the set I get from Toyota will be all one molded piece of silicon so it doesn't come apart
Bust a Deal; Face the Wheel.
Replies (1 - 4)
post Feb 28, 2016 - 2:11 PM
glue the little rubber part to the plug wire with silicone glue and use silicone grease on the plug so the rubber doesn't bond to it. OE wires are Sumitumo not denso I believe.
post Feb 28, 2016 - 4:57 PM
Box
Joined Feb 23, '12
From Warrior, AL
I had no issues with my NGK set, but used conductive grease. Also in the event of such and other snafus hemostats do a marvelous job of retrieving objects in hard to reach places.
2001 Miata LS 5-speed
post Feb 28, 2016 - 11:28 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
QUOTE (Box @ Feb 28, 2016 - 4:57 PM) *
post Feb 29, 2016 - 12:51 AM
Box
Joined Feb 23, '12
From Warrior, AL
Yup, back from when my mom was a registered nurse.
Sure beats going at it with a pick and hook and dropping crap into the engine. tongue.gif
This post has been edited by Box: Feb 29, 2016 - 12:52 AM
Lo-Fi Version Time is now: February 20th, 2025 - 10:17 AM
