> st185 3sgte swap into 3 door 98 celica. help please!
post Apr 24, 2016 - 8:25 PM
98celi
Joined Apr 24, '16
From Colorado
I started a 3sgte swap into my 98 celica just a few days ago. Everything has been going well so far, engine is in on 3 mounts ( fourth is poly filled drying currently) The problem I'm currently having iis being massively overwhelmed by the wiring. The harness was still on the engine when I bought it. Between coolant lines, vacuum lines and connectors I don't know where to start. I spent all day scouring through other forums and posts and haven't find anything as helpful as I'd like. 6 hours today looking at my engine bay and maybe two connectors plugged in. Any help or advice would be much appreciated
Replies (1 - 19)
post Apr 25, 2016 - 8:18 AM
i need more information, what version 3S-GTE?
there are threads in the stickies and my thread is full of wiring information
post Apr 25, 2016 - 9:27 AM
98celi
Joined Apr 24, '16
From Colorado
QUOTE (Smaay @ Apr 25, 2016 - 8:18 AM) *
It is an st185. My only concern is wiring harness doesn't seem to be lining up. My coil and igniter end up centering on the firewall but all pictures I've seen they should be mounted near/above the brake booster
post Apr 25, 2016 - 11:02 AM
richee3
Joined Jun 29, '08
From Denver
The ST185 harness will not work in a T20 Celica. You'll need to have it converted for a 6th gen.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Apr 25, 2016 - 11:31 AM
98celi
Joined Apr 24, '16
From Colorado
As far as conversion, do you mean convert the current harness or work it together with the 22 pin for the third ECU plug?
post Apr 25, 2016 - 12:11 PM
98celi
Joined Apr 24, '16
From Colorado
QUOTE (richee3 @ Apr 25, 2016 - 11:02 AM) *
Found a thread on exactly this problem sorry for the repeat post guys
post Apr 25, 2016 - 12:28 PM
richee3
Joined Jun 29, '08
From Denver
Check out the stickies, there's a ton of great info there including a thread on swapping the 2nd gen 3S into our 6th gens.
http://www.6gc.net/forums/index.php?showtopic=77843
1998 Celica GT-
BEAMS Swapped.
post Apr 25, 2016 - 12:51 PM
98celi
Joined Apr 24, '16
From Colorado
QUOTE (richee3 @ Apr 25, 2016 - 12:28 PM) *
I will have to spend more time in those threads. The wiring struggle has become a large one. I'm fine doing the work just figuring out what I need and what I don't out of two harnesses then combining them is. Interesting ha
post Apr 25, 2016 - 8:49 PM
mkernz22
Joined May 10, '10
From MA
This post has been edited by mkernz22: Apr 25, 2016 - 8:54 PM
post Apr 25, 2016 - 9:12 PM
98celi
Joined Apr 24, '16
From Colorado
Nee question however has come up. The 21 and 22 pin connector on the 3sgte ecu are +B and +B2 respectively. The 5sfe 22 pin connector I'm attempting to repin has a +B on pin 22. But no +B1 listed. How do I repin this?
post Apr 26, 2016 - 12:32 AM
from experience, wiring is easy if you take your time and read and understand.
if you know how to read a map, you can read electrical wiring. You have to understand what a relay does, and how to mate the two harnesses together.
in my experience, what i did is I used microsoft paint, and created a massive wiring diagram, that i printed on several pages.
i combined the engine wiring into my celica wiring, and from there it was simple. it took me weeks to develop this wiring. Yes its for the 2Gr, no its not available.
post Apr 26, 2016 - 12:41 AM
98celi
Joined Apr 24, '16
From Colorado
Sounds good. That's what steps I started tonight. I separated my 22 pin from the 5s harness and will plug it in and then follow it to both 3s harness and 5s harness to see which connector I will have to pull next. Longest part currently is finding the needed wiring diagrams. The labeling and marking for harness separation can be a pain but isn't near as time consuming. There are benefits and downsides to having the engine with the harness already attached. I didn't realize how much wiring there would be with the second gen or I would've pulled the harness before dropping the engine in.
post Apr 26, 2016 - 11:44 AM
Cant stress enough to label each wire
Oh and test for continuity. Last thing you want is to have a broken wire. And not knowing where it is
post Apr 26, 2016 - 3:58 PM
98celi
Joined Apr 24, '16
From Colorado
QUOTE (njccmd2002 @ Apr 26, 2016 - 11:44 AM) *
I have a flow chart setup with labeling. When I pulled the 22 pin from 5s harness didn't disconnect anything. I'm just going through 1 connector at a time
post Apr 26, 2016 - 6:22 PM
98celi
Joined Apr 24, '16
From Colorado
I now have a non wiring question. I do appreciate the help so far guys even with how generic my questions have been. With the engine I got an st185 top mount intercooler. I don't have the external water pump or the sub radiator, is there anything else I need for that setup? And in addition to that my plan was to find universal sub radiator and pump because the stock ones are either very hard to find or they break my budget. The only sub radiators I can find are actually fmic. They aren't just radiators but I was wondering if I can still mount one to the front and run the coolant lines to my top mount? I assume I'll also need a reservoir for the system.
post Apr 26, 2016 - 6:27 PM
98celi
Joined Apr 24, '16
From Colorado
Also in theory is it possible to temporarily run the engine without the intercooler? Just pipe the manifold to the turbo?
post Apr 27, 2016 - 3:31 PM
mkernz22
Joined May 10, '10
From MA
You have an Air 2 Air intercooler, unless it's an RC engine, in which that case it has the Water 2 Air intercooler
post Apr 27, 2016 - 10:37 PM
98celi
Joined Apr 24, '16
From Colorado
QUOTE (mkernz22 @ Apr 27, 2016 - 3:31 PM) *
It's water to air. That's why I was curious about it.
post May 2, 2016 - 6:39 AM
you can wire an external pump...
post May 3, 2016 - 8:08 AM
When i did the 3S swap in Amy's car, I made my own relay setup and used the FC signal as the trigger. so if the fuel pump is on, then the intercooler pump is on. It was really easy to setup.
when I was building V6 swap harness' I took the entire harness apart. then re-pinned each wire. i made sure i had enough length and my color codes were correct.
Lo-Fi Version Time is now: February 18th, 2025 - 6:57 PM
