> Turn signal stalk wiring
post Jun 17, 2016 - 12:30 AM
Shigexile
Joined Oct 30, '03
From IL
Can someone provide me with a picture or diagram of the fog light stalk wiring?
I bought a post-face fog light stalk and as you know, preface USDM models don't have the fog light wires already routed so its not a simple plug-and-play.
So I need to know where the extra wires are wired to.
Can any post-face members help me out please? I want to compare with my preface light stalk.
Thanks!
Replies (1 - 3)
post Jun 17, 2016 - 11:43 AM
jesse09
Joined Jan 19, '09
From Texas
I've did this myself but didn't take any pics. It's just two wires
http://www.6gc.net/forums/index.php?showto...p;#entry1064444
"On your 96+ multifunction switch harness there should be 2 wires that are not on you pre face stalk harness, a green with a black stripe and white with a black stripe.
1. Your going to have to cut your preface harness, as it won't fit into your 96+ stalk and connect the wires from your car to the harness that comes with your 96+ stalk. Just match the colors as they are the same. I recommend soldering as the butt connectors can loosen with steering wheel tilt.
2. Of the two wires mentioned above that were not connected, run a wire from the white/ black stripe cable from your harness to the fog light fuse in your fuse box.
3. Run a wire from the green/ black stripe cable to your aftermarket relay.
4. Test your connection and that should do the trick."
post Jun 18, 2016 - 1:03 AM
Shigexile
Joined Oct 30, '03
From IL
Thanks!
I don't know what the facelift harness looks like so I'll probably need to tinker around with it.
post Jun 18, 2016 - 7:59 AM
The white/black can just go to ground.
The other wire (green/black) sends negative/ground when the fog switch is turned on.
Just wire in a relay for the fogs and run that wire to the negative (ground) for the relay.
Lo-Fi Version Time is now: November 22nd, 2024 - 9:30 PM
