have fuel, have spark, cranks well, won't start |
Nov 10, 2016 - 9:52 PM |
Enthusiast Joined Nov 10, '16 From Vancouver, WA Currently Offline Reputation: 0 (0%) |
Hey all, I've got a 1995 Celica with a 2 L, that I gave a full tune up about 2 months ago. I was driving it with no problem, parked it at home and the next morning it would crank but no fire.
Since, I have checked resistance from coil and distributor. Both checked out fine. I have replaced fuel filter (just in case), seen that I am getting plenty of fuel. Bought a new fuel pump, thinking may be the problem. Did the starting fluid into throttle body, no fire. My next suspicions are the timing belt jumping a tooth (don't see how this could be, as it was running fine when I parked it the day before) or the next is a plugged exhaust. I'm out of options, if anyone has any ideas, I would greatly appreciate it. Thanks in advance, jnylaw |
Nov 11, 2016 - 8:25 AM |
Is the spark strong and able to jump more than 1/4 inch gap in free air easily? A weak coil can check good but lack power to fire under compression.
Mar 25, 2018 - 7:12 AM |
Enthusiast Joined Feb 5, '10 From ireland Currently Offline Reputation: 0 (0%) |
Hey all, I've got a 1995 Celica with a 2 L, that I gave a full tune up about 2 months ago. I was driving it with no problem, parked it at home and the next morning it would crank but no fire. Since, I have checked resistance from coil and distributor. Both checked out fine. I have replaced fuel filter (just in case), seen that I am getting plenty of fuel. Bought a new fuel pump, thinking may be the problem. Did the starting fluid into throttle body, no fire. My next suspicions are the timing belt jumping a tooth (don't see how this could be, as it was running fine when I parked it the day before) or the next is a plugged exhaust. I'm out of options, if anyone has any ideas, I would greatly appreciate it. Thanks in advance, jnylaw I had the same problems a few years ago turns out it was pipe coming out of fuel tank was loosing pressure due to corrosion changed it and it started fine |
Mar 25, 2018 - 3:30 PM |
Enthusiast Joined Mar 6, '17 From Sacramento Currently Offline Reputation: 0 (0%) |
Mar 27, 2018 - 2:47 PM |
Check your fuel filter, and compression in cylinders too.
Lo-Fi Version | Time is now: November 23rd, 2024 - 1:45 PM |
