> How to remove the cylinder head / manifold
post Dec 11, 2016 - 4:53 PM
st185l
Joined Nov 27, '16
From Gran Canaria
Good afternoon, I'm removing the head from the car to replace the gasket.
The problem arises when, to remove the cylinder head, all the wiring that goes above the intake manifold must be removed.
To remove all the wiring you have to disconnect many things, so the solution for me is to remove the intake manifold
This one has reinforcements underneath and some screws from the bottom that grab it to the butt, but you can not put the hand behind.
For the guys who have removed the cylinder head or intake manifold, exactly how did you do it?
Many thanks
p.d: WIRING/CABLE
Lo-Fi Version Time is now: January 15th, 2025 - 9:52 PM
