> parasitic drain experts..., read this
post Feb 11, 2017 - 1:53 PM
i have been busting my back trying to find a parasitic drain. i think i found what drains my battery.
i have 2 options. the aftermarket pioneer radio or the aftermarket alarm. funny.
anyone has had an aftermarket radio do this. its a pioneer.
i have both disconnected and seems too be no more drain. of course i have to see which one is the culprit....
stay tuned
Replies (1 - 5)
post Feb 11, 2017 - 2:42 PM
If you have a good multimeter you can measure the amperage via it's fuse to see how much power the item itself is drawing, a good number for total parasitic draw is about 50ma on a car with a bunch of stuff like you have, it's probably the alarm though, especially if it's a fancier one. My 00 Celica has a steady 30ma draw when sitting off, it's got a factory alarm with features comparable to aftermarket alarms (intrusion, glass break sensor, keyless entry). The radio will have some key off draw to keep settings alive, but if it's got a high draw it could be the bluetooth module inside not going to sleep. I've seen that happen with Honda factory sound systems.
post Feb 11, 2017 - 2:48 PM
the alarm is factory. which is odd.. the radio, is new, but you may be right...
post Feb 11, 2017 - 4:06 PM
very odd, I'd put the money on the aftermarket stuff any day over OEM stuff but weird things happen. How high isn the total draw?
post Feb 17, 2017 - 7:54 PM
not sure if the alarm was the full problem, i also had to replace batery under warranty. so we will have to see.
post Feb 18, 2017 - 10:17 PM
brk34
Joined Jan 20, '08
I had a parasitic drain issue caused by the factory alarm. Clamp on dc current meters are fairly cheap now and would be a good way to check current.
Lo-Fi Version Time is now: February 13th, 2025 - 11:21 AM
