> Hard Start when Cold
post Jun 20, 2017 - 6:00 AM
Jankerfun
Joined Jun 11, '08
From Clifton Park
Replaced plugs, wires, cap, rotor. Fresh oil change, shift solenoids (all 3). P0500 code comes on every once in a while...
When I try to start the car after it sits overnight, or for a few days... The car will start, then the rpms will drop down and it will stall---- OR---- The rpms will drop, and it will hover around 300-400 until I give it gas
Once I give it some gas when I start it, the car runs fine, drives around fine, will restart fine... I don't get it!
Timing belt is old, done at 67k miles and it has 139k on it now. Maybe its out of time or getting week I don't know....
Replies (1 - 3)
post Jun 20, 2017 - 9:30 PM
7A-FE right? Mine did the same thing when it was cooler outside, suspected a bad engine coolant temp sensor but never confirmed.
post Jun 20, 2017 - 9:51 PM
Box
Joined Feb 23, '12
From Warrior, AL
Have you ever cleaned the IACV? Another thing is you could have injectors leaking down and opening up the throttle lets in more air to burn off the excess fuel.
2001 Miata LS 5-speed
post Jun 21, 2017 - 12:14 PM
Jankerfun
Joined Jun 11, '08
From Clifton Park
Nah it's the 5sfe. I haven't cleaned the iacv. I'll try that next.
Lo-Fi Version Time is now: November 23rd, 2024 - 7:45 AM
