> 4a-gze swap, need to clear some things up
post Mar 4, 2004 - 11:47 PM
DustyBurns30
Joined Jul 31, '03
From Panama City Beach, FL
i did a search and have been trying to find info on what goes wrong when people try to swap a 4a engine into their celi's. it said in the feasible swap sticky that there is some problem when you use the 4a tranny and then i read about something going wrong with the power steering pump. does anyone know what exactly the problem is? coomer and mynzeyes, you guys are the ones with the experience, i'm particularly interested in your input.
btw, i know this topic has been discussed a lot, but there is no real clear cut info on it, so if anyone knows where i can find some please let me know.
thanks
post Mar 5, 2004 - 12:36 AM
3FingersCelica
Joined Aug 21, '03
From Endicott NY
From what I've read a major problem is the uncertainty of the wiring. Its hard to come by a good wiring diagram. Some custom work needs to be done for power steering, radiator and a few other things.
post Mar 5, 2004 - 12:44 AM
DustyBurns30
Joined Jul 31, '03
if i got a front clip would that make the difference? then i could use the power steering pump and radiator from the clip correct?
thanks
post Mar 5, 2004 - 12:49 AM
3FingersCelica
Joined Aug 21, '03
From Endicott NY
I'm not sure if the radiator or power steering would be compatable. You should be able to use the ones from your celi, but the hoses will need to be custom made. I'm not sure though coomer would be the best to talk to cuz I'm sure his 4age would be similar.
post Mar 5, 2004 - 2:06 AM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
his 4age could be quite different on the water routing.... "custom" radiator hoses aren't a problem.... just go to the store with a wire hanger in the shape you need... find one similar and cut it to fit.... done
the problem with the 4a-g(z)e motors on PS is that on 4/7a-fe motors the PS pump is on intake side, and on 4a-g(z)e it's on exhaust side.... especially on the 4a-gze since the s/c takes up most of the intake side...
if you got a 1/2 cut then you would have the wiring needed (although, the 4a-gze wiring is only like 2 sensors away from a 4a-ge harness... and my 4a-fe harness was only a couple wire lengths from a 4a-ge harness... so they're similar).....
as far as the tranny not bolting up... i'm not 100% sure... the latermodel FWD 4a-gze trannies (from japan) is an e51 and uses a shorter back mount (according to devin at alloutracing.netfirms.com)... BUT, the c52 tranny you have will bolt up to a 4a-gze... it's what an mr2 came with...
post Mar 5, 2004 - 3:12 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
You can just either PS pump so long as you custom run the proper lines I believe. Depending on which motor you have... the C52 might not fit. It will fit the older AFM 4AGZ's but probably not the later higher comp map versions. I believe those have slightly larger flywheels (220mm I believe as opposed to 212mm) and might not line up correctly with the C52... hence the tranny change in the late model AE92 and AE101. It's also a known problem with the T50 tranny in the AE86's case (with the tranny and housings not lining up). Most people just ditch the PS... although it's a pain in the arse... it's the easy way out. The way I'd do it... use the one from the 4AGZ and run custom lines. Should work...
post Mar 5, 2004 - 3:34 AM
DustyBurns30
Joined Jul 31, '03
is there any way around using my stock tranny, cause it's about 170k old and the syncros are starting to go. would i have to custom make a motor mount or bracket or something?
btw, thanks everybody for this great info your giving me so far. i really appreciate it.
edit: i would like to get the newest 4a-gze i can, depending on if i can use a 4a tranny or not.
This post has been edited by DustyBurns30: Mar 5, 2004 - 3:37 AM
post Mar 5, 2004 - 8:07 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
To add a bit more... you can swap flywheels. I believe if you use a 212mm flywheel (7AFE, Redtop 4AGE, 20V 4AGE) etc... it should fit and work correctly with the correctly sized clutch. They all used the same flywheel bolt pattern, which is 8 bolts (nearly every single A series motor)... however, the only reason not to use the C52 tranny is that it's not as tough as the e51. You'll probably want to either swap flywheels in order to use the C52, or custom build the tranny mount for the e51. Either-or should work. Even better... find yourself a C56 (blacktop 6 speed) and go to town... 4AG trannies typically are pretty cheap... and they are nearly identical to the 7AFE c52.
This post has been edited by Kwanza26: Mar 5, 2004 - 8:10 PM
post Mar 5, 2004 - 8:24 PM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
um... the c52 is good for around 200hp.... so it will be fine..... if you want another c52 tranny don't get a celica or ae102 corolla tranny... find an ae92 gts (corolla) with the c52... it has a better final drive....
the tranny mounts for an e51 don't need to be custom made or anything... one i believe is slightly different but can be made to work..
check here... it's into an ae92... but a celica ST is pretty much the same:
http://soniccreation.com/how_to_make_a_crayon_streak.htm
and yes.... the 4a-ge's all use an 8 bolt pattern flywheel (4/7a-fe's DO NOT however... they use a 6 bolt)... you can use an ae86 or early model ae92 flywheel (which is what i'm doing on my smallport 4a-ge) w/o any problems and use the smaller clutch/pressure plate
post Mar 5, 2004 - 10:24 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (toyotaspeed_90 @ Mar 6, 2004 - 1:24 AM)
Really? I thought the bottom ends were nearly identical... and used the same pattern on the flywheel aside from the old 3AC/4AC's and stuff. I could be wrong... but I'll have to check that out. As for the C52... he said he wanted to swap out if at all possible because his tranny's old.
post Mar 6, 2004 - 1:16 AM
DustyBurns30
Joined Jul 31, '03
will i have any problems with axle length of the stock 4a's, or should i use my 7a axles.
now for my dumbest questions of the thread (brace yourself):
will the e51 tranny come with an ae101 or ae92 clip?
- is there a site that lists basic specs of the different 4a engine/tranny combos? i looked at club4a but i didn't find anything. (google will be the next stop)
- i'm not looking to go cheap but with the list of parts i want to get i would like to save money where i can.
do you guys recomend a limited slip?
- my guess is that i don't have to worry too much about it unless i get over
200hp.
thanks
post Mar 6, 2004 - 12:21 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (DustyBurns30 @ Mar 6, 2004 - 6:16 AM)
200hp.
Either set of axles should fit, and there have been people saying that the lengths are correct also... but to be sure... test it out. Whether it fits or not, you'll still have the 7A axles which will fit.
As far as the tranny goes, I believe it comes on the late model map sensored 4AGZs which is on the 1992+ AE101 levins and possibly even on the slightly older MAP version of the AE92 Levin/truenos. The late model ones were tuned slightly different, used DLI (distributor-less-ignition), had slightly higher compression, and came factory with slightly higher boost. Overall, they're just as capable as the older distributor types... but because they're afm, they're easier to tune. LSD is good, but I don't know if any of those trannies came with factory LSD. Some claim the 6 speed C56 had factory LSD... but no-one really knows for sure. I'll figure it out eventually though. It will be good to have LSD, but you should be ok without it. IF you plan to overdrive it though... then LSD is reccommended, considering a good Nevo or HKS pulley can boost around 12-14 psi and drop around 160-170 horses to the wheels....
post Mar 6, 2004 - 2:44 PM
DustyBurns30
Joined Jul 31, '03
sweet, thanks for the info.
moderators, can we make this a sticky? this is the best info i have read about this swap and i'm sure this will help many people in there quest for a 4a. thanks again to kwanza, toyotaspeed, and 3fingers.
one last question though, do all the 4a-gze's use pretty much the same parts as far as stock replacement? what i mean is can i go to any parts store and find the little odds and ends that can't be replaced with performance parts or will i have to special order jdm parts?
thanks again.
post Mar 7, 2004 - 2:41 AM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
yes..... they all use the same parts (except for some of the internals... but parts from an earlier mr2 4a-gze will work.... like pistons & whatnot).... if you use the map setup some of the electronics may be a little different... but again, same as the internals.....
post Mar 7, 2004 - 2:46 AM
qatar11
From Lake Orion, MI
Coomer, John and Ryan have the mechanical part done and im hacking through the wiring
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Mar 7, 2004 - 3:29 AM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
QUOTE (qatar11 @ Mar 7, 2004 - 7:46 AM)
post Mar 7, 2004 - 12:54 PM
qatar11
From Lake Orion, MI
QUOTE (toyotaspeed_90 @ Mar 7, 2004 - 1:29 AM)
yes and that is not correct for every variation of the 4AGZE....
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Mar 7, 2004 - 1:57 PM
Mynzeyes
From Franklin/Nashville, TN
seeing as how i'm using the tranny out of the clip, that the GZE is meant to use:
the AE92 axles that came with my clip did NOT fit. the longer, passenger side axle was correct, but for the driver's side, i had to send the clip axle off to RAXLES.com to get it extended a little over an inch. Also, with the beefier GZE axles, i had to grind down on the crossmembers just a little (not enough to compromise strength). also, as far as the motor "dropping right in", that is not the case. the driver/passenger/front tranny mount all will bolt right in, using both clip and celica mounts (you have to change out certain parts), however, the rear mount (near the firewall) i could not get to mount correctly. i had to drill out the crossmember, and bolt it in on my own.
As for the power steering. i have adapted the 2 lines to each other, but it is still a matter of whether my method will work or not, i will tell how i did it only if it works, as i'm not going to tell you the WRONG way to do it. tongue.gif.
the radiator. i used the stock celica radiator, plugged up some spots at the bottom that the GZE did not utilitze, and got a hose that fit from autozone....
AIM==Mynzeyes
post Mar 7, 2004 - 1:59 PM
Mynzeyes
QUOTE (toyotaspeed_90 @ Mar 7, 2004 - 2:29 AM)
yes, mike is right, this is not all there is...
USDM: AFM w/ distributor ignition.
JDM: AFM w/ DLI (distributor-less ignition) (AE92)
JDM: MAP w/ DLI (AE92)
JDM: MAP w/ DLI (AE101)
and yes, those last 2 have different wiring.
AIM==Mynzeyes
post Mar 7, 2004 - 4:18 PM
DustyBurns30
Joined Jul 31, '03
mynzeyes, did you use the 7a-fe wiring harness or the 4a-gze, or a combination harness? is it possible to use the 4a harness and just extend the wires and adapt it at the gauge cluster, or do you have to adapt the 7a harness to the 4a engine and ecu?
Lo-Fi Version Time is now: November 28th, 2024 - 6:47 PM
