4a-gze swap, need to clear some things up |
Mar 7, 2004 - 5:40 PM |
Enthusiast Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
that is Mike's area. you have to adapt the 4AGZE engine harness to work w/ the AT200 body harness... -------------------- |
Mar 7, 2004 - 6:05 PM |
Enthusiast Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) |
Actually i dont have the mechanical part done, I'm waiting for mike to finish the harness. Once that is done the rest should get done rather quickly.
-Ryan -------------------- AIM : FAQdaWorld
Mar 7, 2004 - 7:17 PM |
Enthusiast Joined Jan 22, '04 From bellingham, WA Currently Offline Reputation: 0 (0%) |
like i said... (at least on ae92 corollas) the back tranny mount doesn't fit quite right... and check the above link i posted... it talks about his entire swap..
the harness: you could adapt the 7a-fe harness to work.... it matters on what 4a-gze you get and what ecu you get (ie... you use MAP it will be easier... but if you get an afm setup you'll have to run those wires)... some other wires have to be extended & whatnot... no biggy... i'm using a 4a-fe harness on a 4a-ge and extended all of 3 wires.... the downside of using the 7a-fe harness is that you'll have to change the plugs for the ECU... and you'll have to go wire hunting.... and i know those aren't the only wiring schematics for the gze... those were 2 i found quickly over on club4ag..... |
Mar 7, 2004 - 9:53 PM |
Enthusiast Joined Jul 31, '03 From Panama City Beach, FL Currently Offline Reputation: 1 (100%) |
yeah, i read about that one guys swap. i had it in my head that i was going to use the 4a-gze wiring harness, but i just wanted to make sure that there wasn't an easier way.
thanks. |
Lo-Fi Version | Time is now: November 28th, 2024 - 6:40 PM |
