2 Pages V  < 1 2
> Transmission Swap OR 7afTe, ??Tranny or Turbo??
post Mar 7, 2004 - 1:52 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (Sev408 @ Mar 7, 2004 - 10:01 AM)
well 97sccelica your setup you said cost almost $3gs, how would that compare to a setup that costs $1500?
I mean this car has got to last another 4-5 years all the way through college. I cant work while playing lacrosse and if i quit lacrosse then i loose scholarship.
a $1500 setup is bare bones run no more than 4psi
with my setup, aside from injectors, the only onther things i could have done would be porting and internal mods.
i got mine running for $1600(again, bare bones, no means of adjustment, juust running rich and a little faster than a stock GT) with 4 weekends of labor, and just added stuff as i went along. but i spent a lot of time parts hunting and that saved me a lot of money at first, after a while i just decided to buy the first stuff i came across. i bought metal IC piping and a FMIC to replace the dsm smic and abs piping i had. and fuel pump and other things that kept adding up.
my setup is now 100% bolt on(even comes with a oil pan) with the exception of the fmic setup, it was never used and neither was the piping, so those have to be cut to fit(easy)
it was great while it lasted, and i am very tempted to do it again, but my sister want my car, which will give me a chance to get something either RWD or AWD
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Mar 8, 2004 - 7:49 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
my motor went due to some bad gas, and probably due to me... i drove it like i hated it.... but seriously for about 2k u can do it. just lots of shopping and u have to not be in a rush.
post Mar 8, 2004 - 11:36 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (zipstrips @ Mar 8, 2004 - 4:49 PM)
exactly
dont rush anything
post Mar 10, 2004 - 5:13 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
Hey man, honest: You're not going to have a reliable turbo setup for less than $3,000. Main importante things with this engine: FUEL PUMP...get a BIG one before even saying the word turbo besides it. Second, INJECTORS, and third IGNITION TIMING. QUALITY EVERYTHING...these engines are hexed from the factory...even the most stupid little thing will mess it up...even wrong oil.
post Mar 10, 2004 - 7:02 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
QUOTE (OOBE @ Mar 10, 2004 - 3:13 PM)
haha im still looking for the right set of injectors.. until than my stocks are maxxed
post Mar 10, 2004 - 9:31 PM
hyp3rk1d
Joined Sep 22, '03
i thought u didnt even really need new injectors, just a new fuel pump?
post Mar 10, 2004 - 10:51 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (hyp3rk1d @ Mar 10, 2004 - 6:31 PM)
get a RRFPR and a new fuel pump and you should be good, to a certain point
i think zipstrips was at 11psi and still getting enough fuel.
anytihng under that, just go for a new pump and RRFPR(and safc will help too)
post Mar 12, 2004 - 12:09 AM
KnightRider
i have been through the turbocharged st stage an all i can say is that a turbocharged car is only as dependeble as you allow it to be. i think that some people dont really see turbocharging as a big to-do anymore. if you really take your time, research a lot, not just on your car, but the aspects of an engine you will find that you will be able to build a dependable turbocharged motor. i say leave the automatic and BOOST IT!!!
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 3rd, 2024 - 2:38 PM
