> st215 3sgte-swap, possible
post Mar 6, 2004 - 11:48 AM
bustown
Joined Feb 11, '04
From columbus, ohio
i found a st215 260hp 3s-gte with 5sp awd man tranny ecu wiring harness i was wondering if this swap would be possible in my 94 st hatch i am willing to spend money im want to do this instead of buying a new RSX i dont wanna think about having to get rid of my celica frown.gif
post Mar 6, 2004 - 12:02 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
yeah, its def possible.. the awd tranny wont, you will have to get a gt tranny and put that in.. you might wanna look for a front clip, cause you'll also need mounts and i think thats baout it, I would say search past threads.. that will give you the best results
post Mar 6, 2004 - 12:32 PM
Jabberwock
Joined Sep 22, '03
well you should get the whole front clip or else you will have to go part searching and for a ST215,...its practically impossible to find parts in the US.
post Mar 7, 2004 - 2:44 AM
qatar11
From Lake Orion, MI
QUOTE (bustown @ Mar 6, 2004 - 9:48 AM)
i would steer clear of the ST215 motor... its hard enough getting parts for the ST205 let alone the next version of that motor, on top of it all, the wiring system in toyotas have evolved a bit and with the use of CAN the ECU may require a hook up to the body control module to run, a BCM you won't have in your car i might add
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
Lo-Fi Version Time is now: November 28th, 2024 - 9:01 AM
