gt4 1/4 time |
gt4 1/4 time |
Feb 2, 2003 - 5:40 AM |
Enthusiast Joined Sep 22, '02 From wheat ridge, co Currently Offline Reputation: 0 (0%) |
what do the 3 gen gt4 run above sea level
Feb 2, 2003 - 11:25 PM |
I think I remember hearing 6.6 to 60 in the 5th gen. Sounds a little high though for an AWD 200hp sub 3000 pound car.
Feb 3, 2003 - 4:56 PM |
3rd gen? no clue...can't be too great though, since the GT4 seemed to have gotten faster in time
Feb 4, 2003 - 5:22 PM |
Enthusiast Joined Nov 13, '02 Currently Offline Reputation: 0 (0%) |
elevation matters, because the density of air changes at various altitudes.
do you mean 3rd gen g4 or a gt4 with a 3rd gen 3sgte? |
Feb 8, 2003 - 8:55 AM |
Enthusiast Joined Dec 2, '02 From Gainesville, GA Currently Offline Reputation: 0 (0%) |
sub 3000 lb car??? what are u talkn about?? |
Feb 8, 2003 - 12:37 PM |
Are they heavier than that? I really have no idea since I'm not a fifth gen guy, but I would've guessed that, simply because my car weighs under 2400 lbs. from the factory. Edit: I just did some quick research, and it looks like the fifth gen Alltrac Turbo weighs 3219 lbs. It looks to me like all of the sixth gens lost some weight from the fifth generation, because my ST coupe weighs 251 lbs. less than a fifth generation ST coupe. This post has been edited by Coomer: Feb 8, 2003 - 12:45 PM -------------------- New Toyota project coming soon...
Feb 8, 2003 - 11:31 PM |
Man, I had no clue they weighed that much. They were a little fat weren't they.
Feb 13, 2003 - 6:51 PM |
sorry guys i ment what does the st205 run in the 1/4 i heard it runs mide 14's
Feb 14, 2003 - 12:37 AM |
Enthusiast Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) |
mine ran a 13.46 on 16 inch tires with just intake, irudium plugs, nology wires, HKS cam gear and a custom exhuast. didn't have a chance to run it after the HKS cam shafts and some of the other stuff.. will run it agian at the local track this summer and let you guys know what it runs with the new stuff I am doing.
If I can find the time slip for that run I will scan it and post it here -------------------- 99 project version 3.0.. hello SEMA 2010 =) |
Feb 14, 2003 - 1:06 AM |
with the 3's and Front wheel drive?
Feb 16, 2003 - 2:27 PM |
13's sound really low
think about it, sure it has AWD, but the MR2 has close to same power...midship engine, with rear wheel drive...it hits 15's stock i'd imagine that a GT4 should run 15's too it's a bigger car, with a big more power, and of course more weight the main idea is that is has a much greater potential than a ST or GT -------------------- |
Feb 16, 2003 - 2:58 PM |
Enthusiast Joined Jan 29, '03 From colorado Currently Offline Reputation: 0 (0%) |
the mr2 runs 14's stock with less hp then the gt4 so the gt4 should run mid 14's
Feb 16, 2003 - 11:50 PM |
I'll just go get on grand turismo and time it.
Feb 17, 2003 - 12:23 AM |
Enthusiast Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
hahahahahaha, dude, you just beat me to it -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Feb 17, 2003 - 2:04 AM |
that was with AWD -------------------- 99 project version 3.0.. hello SEMA 2010 =) |
Feb 17, 2003 - 2:26 AM |
Enthusiast Joined Jan 5, '03 From Bay Area Currently Offline Reputation: 0 (0%) |
Question: Do Supras(93-99) run 13s stock without basic setup?
NEVERSTOP, I think you could hit high 12's with that setup if you try again. It's possible. Consynx, Mr2 is designed to be as a drag car so its handling isn't as good Celicas....think about it. As far as my guess I'm pretty sure that stock GT-4(6th gen) could run mid 14's stock. |
Feb 18, 2003 - 12:18 AM |
I didn't think you had the AWD working yet?
Lo-Fi Version | Time is now: November 28th, 2024 - 7:11 AM |
