> Would you buy a TDO6 Turbo kit......., For 3SGTE
post Mar 11, 2004 - 7:26 AM
0Re0
Joined Nov 13, '02
From Hawaii
Used TDO6 17c turbo, adapter plate, manifold(bored out) down pipe, fits 5SFE or 3SGTE.... all custom now....tested up to 24 PSI
Would you buy the kit for $700 ?
post Mar 11, 2004 - 8:13 AM
Depends on mileage, but thats a very good price.
Also consider that its not plug and play, u'll probably have to run new oil lines.
This post has been edited by Supersprynt: Mar 11, 2004 - 8:13 AM
post Sep 17, 2006 - 10:57 PM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
as well as an EMS and fuel system upgrade (REQUIRED) and ignition upgrade (strongly recommended)
post Sep 18, 2006 - 2:01 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
OT: WHats happening with the car in your life after celica??
<<<<<< DCw / JDMart >>>>>>>
post Sep 18, 2006 - 11:08 AM
gt_driFFter
Joined Nov 29, '04
QUOTE(celicast3sgte @ Sep 17, 2006 - 11:57 PM) [snapback]480865[/snapback]
as well as an EMS
Why? There are a ton of guys on mr2oc running the tdo6 without an ems, why would it be different for a celica?
Same goes for fuel upgrades, a lot of those guys are running stock injectors, etc.
post Sep 18, 2006 - 11:12 AM
scothaniel
Joined May 1, '03
From Michigan
$700's not a bad price, but I'm not sure about the 17C turbo. Its between a small 16G and big 16G in size - which is a good thing. Pry 500CFM of flow at 15PSI. But the 16G's use the tD05 exhaust housings which are smaller and spool quicker. TD06 will give you more flow, but more lag.
I have a td05-14B on my FWD celica and it spools fairly quickly. Once I hit the 3500 rpm range, it seems like a totally different car - the boost comes on so strong that the 4000 - 7000 rpm range is a blur.
I have a td06-20G on my all-trac. Spool hits a little later - 4700 rpm or so, but then it pulls really hard to red-line. Definately more power, but not as quick.
The 16G is probably the best ballance for a street car. If the 17C is comparible, it'll be a fun ride.
FYI - I made an adapter for the stock manifod for $70 using 2 flanges and a piece of 2.5" pipe welded together. Bought the 14B for $100 and the O2 housing for $120. The rest of the downpipe was a 2.5" long elbow and 2 flanges - $50 welded. Custom oil lines are another $100 or so.
Scott
West Michigan
post Sep 18, 2006 - 11:32 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
2004? Why did this need to be brought back from the dead?
post Sep 19, 2006 - 9:59 AM
gt_driFFter
Joined Nov 29, '04
QUOTE(gt_driFFter @ Sep 18, 2006 - 12:08 PM) [snapback]480971[/snapback]
as well as an EMS
Not trying to be an ass here, Sometime in the next couple years I would like a TD06 MR2, so I'm doing my research now. smile.gif
Lo-Fi Version Time is now: January 12th, 2025 - 4:44 AM
