Shaved license tag |
Mar 15, 2004 - 4:35 PM |
Enthusiast Joined Mar 8, '04 Currently Offline Reputation: 0 (0%) |
you should save your money and do it yourself. cheapest way i can think of doing it is to bond a cut of steel or wood inside the recess. then start to build it up with bondo and top it off with fiber resin. then sand and fill in until you are happy with the shape. wet sand, wet sand, wet sand, primer, wet sand, primer and get it painted. now that wasnt hard at all now was it?
Mar 15, 2004 - 5:07 PM |
Enthusiast Joined Oct 1, '02 From Belgium Currently Offline Reputation: 0 (0%) |
Well at first i took out the light and the cable!
Then i sprayed some faum (i do'nt know how it named) to fill up the hole: 1) ils very light! 2) after its dry you can cuut oof the rest and sandpaper it like you want! After that, put a layer fiberglass over an paint it!! Thats all!! |
Mar 15, 2004 - 5:50 PM |
Enthusiast Joined Aug 30, '02 From Ohio Currently Offline Reputation: 0 (0%) |
that sounds easier
-------------------- Jared Harwell
Lo-Fi Version | Time is now: January 11th, 2025 - 3:49 PM |
