Puddle of oil, gradually growing under the car... |
Feb 3, 2003 - 5:21 PM |
Enthusiast Joined Oct 9, '02 From San Diego, CA Currently Offline Reputation: 0 (0%) |
Ill be taking my baby into the shop on Wednesday... whats the worse that it could be and whats the best? Just so I can be on my feet.
Heres a few things I suspect, add on or correct me if you see any error. - Oil pan gasket or oil pan drain bold washer leaking - Oil pressure sending unit leaking - Cylinder head cover leaking - Oil pump housing leaking - Engine oil seals leaking |
Feb 3, 2003 - 5:23 PM |
Enthusiast Joined Aug 30, '02 From Los Angeles, CA Currently Offline Reputation: 0 (0%) |
sounds like you pretty much have the best to worst covered - hopefully all it is is just the gasket leaking - that's not that much money and easily fixed. good luck!
Lo-Fi Version | Time is now: December 4th, 2024 - 6:11 AM |
