ECU with 7a Transmission swap?, Do i need to swap out the ecu? |
Mar 17, 2004 - 2:45 PM |
Enthusiast Joined Dec 4, '03 Currently Offline Reputation: 0 (0%) |
Im doing a transmission swap and have gotten most of my parts together. However my dad and i are unsure if I need a ecu from a manual 7a motor or if i can use the automatic ecu that i have now??
I also want to know if i need a new half shaft?? I have heard different things and TAP recycling is unsure. -------------------- hows it taste motha f*cka
Mar 17, 2004 - 3:17 PM |
Enthusiast Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
from what i've been told u can use the auto ecu for manual swap but u can't use a manual for a automatic so u should be set.
-------------------- All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Mar 18, 2004 - 3:39 AM |
Enthusiast Joined Jan 22, '04 From bellingham, WA Currently Offline Reputation: 0 (0%) |
racer25 did an auto-> manual swap in his ae102 (7a-fe) and used the auto ecu. The only issue is either a check engine or a tranny? light. I don't remember at this time.
Mar 18, 2004 - 11:10 PM |
Enthusiast Joined Jan 20, '04 From TN Currently Offline Reputation: 0 (0%) |
if your car has O/D then you may run into problems w/ the ecu if you want it to go smoothly i suggest using a ecu from a 5spd or a 3 spd auto
the reason is the 4 speed auto(3speed w/ overdrive) is electronically controlled by the ecu |
Mar 19, 2004 - 10:28 PM |
and with a manual tranny you're in control.... all it will do is throw a light |
Mar 23, 2004 - 8:53 PM |
Anyone know if i need a new half shaft or axles?? -------------------- hows it taste motha f*cka
Lo-Fi Version | Time is now: November 30th, 2024 - 6:04 PM |
