Armor All spots on plastic, how to remove them? |
Mar 21, 2004 - 10:40 PM |
Enthusiast Joined Sep 6, '02 From maine, usa Currently Offline Reputation: 0 (0%) |
There are spots on my gauge cluster from where Armor-All sat for a while, and I can't seem to remove them with anything.
Anyone know of a way to remove the spots? |
Mar 21, 2004 - 10:51 PM |
Enthusiast Joined Sep 5, '03 From Grapevine, TX Currently Offline Reputation: 0 (0%) |
Try rubbing some more armor all on it, let it dry for a minute or so, then rub it off. It's like a reverse method to get it off, but it should work--and if it doesn't, it won't get it worse. I have accidently gotten it on my A/C panel, and it wiped off, but try this method.. it's similar to like when you get a permanent marker on a dry-erase board. It won't come off, but if you use a dry erase marker over the permanent marker, then wipe off the second 'layer', it'll remove the permanent marking as well. Best reference I could think of. Try it out.
-Brian |
Mar 21, 2004 - 11:15 PM |
Thanks, I'll give it a shot.
Mar 21, 2004 - 11:37 PM |
Enthusiast Joined Sep 18, '02 From San Diego, CA Currently Offline Reputation: 0 (0%) |
Yah, I think that'll work also. I guess where the Armor-All sat it just got extra moisturized. -------------------- [toyota]
Mar 21, 2004 - 11:46 PM |
I don't think it's working.. it looks like it works.. the armor all hides the armor all spots, but if I use window cleaner to get the armor all off, the spots return.
I'm thinking the plastic itself is damaged, but idunno. Someone on a car detailing site suggested I try engine degreaser. That scares the hell outa me, especially since it's the clear plastic on my gauge cluster that I'm worried about. If worst comes to worst, I guess I can either keep my gauge cluster armor all'ed, or buy a replacement bit of plastic from Toyota. (Which I am sure will be retarded expensive) |
Mar 21, 2004 - 11:50 PM |
get some distilled water and a cotton cloth...damp the cloth and rub aways... if that doesn't work then put some viniger on colth...
Mar 23, 2004 - 12:17 PM |
Enthusiast Joined Nov 21, '02 From downey, l.a. county, ca Currently Offline Reputation: 0 (0%) |
for now just put the armor all and wipe. don't clean it up with anything else. that's all you can do by the sound of it. at least you won't see the spots for now.
Lo-Fi Version | Time is now: November 27th, 2024 - 7:49 PM |
