> Custom Sub Incloseures, What should I do??
post Mar 25, 2004 - 2:03 PM
94silverst
Joined Feb 20, '04
From Washington
I'm planning on putting in 2 10" Rockford Subs in my ST, and an amp. What should I do confused.gif ?? I don't really want to do an ordinary box. I would like to do some custom work, not to pricy though wink.gif ! Any one have any ideas or pics of theres??
post Mar 25, 2004 - 2:20 PM
DmVinny
Joined Feb 23, '03
From Florida
I suggest molding one out of fiberglass... if u look online theres tons of how-to's for it...
its fairly cheap, and not that hard, plus it gives u more flexibility in your design and is also strong as hell =)
post Mar 25, 2004 - 9:29 PM
Yeah, I'd go with a fiberglass enclosure, or a MDF enclosure where the subs are made flush with part of the trunk. smile.gif
post Mar 25, 2004 - 9:55 PM
94silverst
Joined Feb 20, '04
From Washington
I was looking around the net on fiberglass and it looks so complicated!! Where should I start??? How do I mold the fiberglass?? Do I make a templete?? confused.gif
post Mar 26, 2004 - 5:07 AM
celimanST
Joined Nov 15, '03
From mississippi
Try this site I found it when I was research for my enclousre.
fiber glass info
A lot of good basic info if you still think it may be to difficult drop me a line and I will help
peace out and good luck hope this helps
William
post Mar 27, 2004 - 2:05 AM
pxcr440
Joined Sep 6, '03
From hudson ,iowa
i have plenty of experience with fiberglassing subs and stuff , first you need to decide what kind of box you want you can flush everything into the spare tire well which is easy cause you dont have to spend all the the time sanding , you could start a normal desinge box and add rings to angle your subs what ever direction ""facing back assummin"" youcould then then mound the amp on top in fiberglass , and finish it off with a flush cover that exposes onlly the glassed parts and makes them stand even more , pic of normal box with rings mounted and cover on profile , just send me message and your need anymore help
Lo-Fi Version Time is now: November 30th, 2024 - 7:56 PM
