> where to run the wires, from the main to the engine
post Mar 25, 2004 - 7:34 PM
acenova
Joined Dec 21, '03
From Portland, OR
where do I run the wires from the main compartment to the engine and the battery? Like where's the hole at that I can squeeze the wire throught?
post Mar 25, 2004 - 9:15 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
it is on the passenger side its like a little boot (looks like an old style shift boot for a truck) poke a coat hanger through it and push it down untill you see it come out under you glove box, then fasten the wire to the coat hanger and push it through
post Mar 26, 2004 - 5:12 AM
celimanST
Joined Nov 15, '03
From mississippi
I would recomend going to your mehcanic and have him drill you a hole on the drivers side.
William
post Mar 26, 2004 - 11:37 AM
Or you can save ur self some time and money and actually drill a hole urself.
post Mar 26, 2004 - 11:56 AM
shid
Joined Jan 8, '04
From LA
I already have a hole on my drivers side?
post Mar 26, 2004 - 12:10 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
if ya havnt gotten it already, just run it through the rub cover.. Thats were i did mine, heres a pic, then run it right down, you will most likely need to remove your glove box an stuff.. heres a pic to get an idea. user posted image user posted image
post Mar 26, 2004 - 1:24 PM
Clipsetuner
Joined Sep 12, '03
From Portland , Oregon , United States
The Use-less Ghetto Install everyone Does.....
The Nice Install I did With hardley any wires showing, and not having anything
running near/over the engine.
DTE
I am a thief.
do not buy anything from me.
post Mar 26, 2004 - 1:35 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
clipse if your gonna critisize our techniques you coudl atleast elaborate on yours smile.gif
post Mar 26, 2004 - 1:44 PM
Clipsetuner
Joined Sep 12, '03
First I ripped out that old install. The Fuse and Most of the wire was destroyed. I picked up 35ft of 4g wire from sounddomain ( here in 2 days nice ). I was gonna run it threw the driver side then figured there wasnt a whole big enough inside ( where the wire come threw the side inside the cab, 8g Might fit tho). So I took off the inner and fender on the passenger side and laid out How I think it should go cut to the right length and started Zip Tieing.
I looped around the battrey with about 9" of wire then mounted a Phenoix gold Fuse. I went under the front crossmember attaching the wire to the exsisting Loom and also zip tieing threw the extra holes. went the rest of the way across the front cross member I twisted the cable a lil bit so looking from the front or straight down couldent see it ( I know im anal ) Into the fender cavatee it went. I continued to attach it to the exsistin loom with zip ties. To get it into the cab you have you have to cut a very very small hole in one of the 2 ruuber groments Strech it to get your wire threw, then I filled it with a slicone sealer then wrapped it up with electric tape.
Total time 4-6 hours.
DTE
I am a thief.
post Mar 29, 2004 - 10:34 AM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
I ran mine from the battery into the fender. Over the wheel well and into the boot behind the fuse/wiring block in the drivers kick panel. Just use some rtv to seal the boot well. Pulling a few of the wheel well clips lets you peal it back for access.
post Mar 29, 2004 - 2:56 PM
DmVinny
Joined Feb 23, '03
From Florida
For a nice install your gonna need these as well...
Battery Terminal
In-Line Wafer Fuse Holder....
And of course the Wafer Fuse.
This post has been edited by DmVinny: Mar 29, 2004 - 2:59 PM
post Apr 2, 2004 - 2:11 AM
Andason
Joined Jun 26, '03
From Wisconsin
QUOTE (AudioFreak @ Mar 29, 2004 - 8:34 AM)
thanks audiofreak, I ran my wires today and its marvelous there.
i am awesome
post Apr 2, 2004 - 11:47 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
hey i have a question, How many of you run just standard fuses, or a breaker? my min reason is, because any time i screw with my wiring i manage to blow the fuses, juts me being stupid , and trying out dif stuff.... but sence i no longer work at bestbuy and i ran out of them, it dont feel like wasting 5 bucks a pop... so if any one has any idea, please let me know. Thanks
post Apr 2, 2004 - 12:01 PM
Clipsetuner
Joined Sep 12, '03
you can pick up 4 fuse's for a Buck at most car shops.
DTE
I am a thief.
post Apr 2, 2004 - 7:19 PM
AudioFreak
Joined Dec 19, '02
QUOTE (Digndoug @ Apr 2, 2004 - 12:47 PM)
Breakers are nice. Let you flip off the power eaisly. But they can go bad... I've seen a few. If you really wanna protect yourself. Put a fuse between the breaker and the battery that rated higher than the breaker. If the breaker works as it should the breaker will pop before the fuse. I'd go atleast 30 amps bigger than the breaker. If the breaker fails and there is a short the fuse still protects the wiring.
This post has been edited by AudioFreak: Apr 2, 2004 - 7:22 PM
Lo-Fi Version Time is now: November 27th, 2024 - 4:29 PM
