![]() Enthusiast ![]() ![]() ![]() Joined Sep 29, '02 From Sterling Heights, Michigan Currently Offline Reputation: 0 (0%) ![]() |
This just started to happen about 2 wks ago and since then it's happened every so often. But when I'd lock my car with my remote, the "beep" would get softer and quieter. When I'd do it again it would go lower and lower, etc.
Then it would act fine again with the normal tone on the 4th time I'd do it. Does anyone know what it might possibly be? Like a fuse or faulty wiring or something? Thanks, Christee |
Enthusiast ![]() ![]() ![]() Joined Apr 29, '03 From Davenport, IA Currently Offline Reputation: 0 (0%) ![]() |
Hell I got the same ****in problem. My horn was doing the same thing and I just charged my battery to see if that helped......nope! so I just kinda waited it out and eventually it went back to normal, probably over using a stock part
Yeah my dad said the same thing, how I might be using the alarm too much? But still...? I just hope it won't start tripping out eventually! It's fine again, so guess in about 1 week 2 it'll do the same thing again.
Well mine is working fine again so I dunno. I'm gonig to be buying a new alarm with digital auto starter. I would probably suggest just get a new alarm, if you want somefin simple and not too pricey should only cost around $100. I can't see a simple one costing more than that.
Lo-Fi Version | Time is now: February 20th, 2025 - 2:58 AM |
