> Can you install an amp and sub to factory stereo, Is it possible?
post Mar 31, 2004 - 12:57 AM
JZUM
Joined Nov 19, '02
From canada
This might sound like a dumb question, I have no clue about audio. I have a 95 celica gt with 8 factory speakers (i think) and wanted to know if I can install an amp and a sub with just the factory stereo?
post Mar 31, 2004 - 1:08 AM
PuffDog
Joined Dec 9, '02
From Houston,Texas
yes but you have to buy a converter for the signal wire whick is only like 20 bucks
post Mar 31, 2004 - 6:07 PM
pxcr440
Joined Sep 6, '03
From hudson ,iowa
true you can use the converter , as i have on many other cars for other people , but the quality is not as great as useing correct cables , i would suggests getting an aftermarket deck the some subs if you want it to sound the best , but it up to you it will still work with the converter as well just make sure you buy a good one , i have heard that the JL amps well exept the signal without a converter by putting rca plugs on the speaker wire from the speaker s ,but not for sure never heard of it
post Mar 31, 2004 - 6:33 PM
DmVinny
Joined Feb 23, '03
From Florida
it is called a LINE OUT Converter...
http://store.electrogalaxy.com/sisloc80.html
post Apr 1, 2004 - 10:43 AM
FAQdaWorld
Joined May 24, '03
From Milton, Delaware
Some amps have low / high (?Forget which its called) level inputs which is basically just the stock wire input from your cd player. So yes.
-Ryan
AIM : FAQdaWorld
Lo-Fi Version Time is now: January 10th, 2025 - 5:11 PM
