> [Would Changing Sparkplugs Increase Performance?], [Would Changing Sparkplugs Increase Perf
post Feb 6, 2003 - 11:55 PM
hioctane
Joined Nov 26, '02
post Feb 7, 2003 - 12:22 AM
FallenHero
Joined Dec 26, '02
From Alabama
if you are thinking irridium, don't do it. I have heard it can cause engine trouble in the worst way.
post Feb 7, 2003 - 12:56 AM
Guest_Matthew_*
you wouldn't really notice it unless your spark plugs were completely fried, your boots were worn like a catchers mit and they sparked like when you touch someone and you have a lot of static electricity in you. Other than that you are gonna have to get new plug wires, and distrubitor and possibly ignition.
Matt
post Feb 7, 2003 - 1:09 AM
ghostdog
From ny to philly
I just recently switched from platinums to iridium and got new wires while I was at it. I noticed a difference in throttle response, and smoothness both at idle and WOT. It could be psychological, but I think it was a good investment nonetheless.
post Feb 7, 2003 - 1:51 AM
FallenHero
Joined Dec 26, '02
From Alabama
After you ride with those plugs for several months, take one out and look at your piston. if the plug's starting to wear a hole in it, let me know. thumbsdown.gif
post Feb 7, 2003 - 2:04 AM
Guest_Matthew_*
yea g dog is right. Wires and plugs will give you a little noticeable throttle response. Plugs alone won't do the trick.
post Feb 7, 2003 - 2:52 AM
post Feb 7, 2003 - 6:50 AM
west_minist
Joined Oct 27, '02
From Barbados
It would. Maybe by 1-2hp, but you will notice a smoother engine around high rpm's.
All of this depends on tuning and driving style.
West_Minist
Hydra EMS Dealer & Tuner
Subaru ECUFlash Tuner
http://www.socob.bb
http://xtremeracingtuning.com
Viciously Tuned, Driven Hard
post Feb 7, 2003 - 10:57 AM
GTS_Bun
Joined Oct 21, '02
From Toronto, Canada
I installed NGK iridium plugs on my car. I don't notice much gain in hp. However it seem to improve fuel efficiency a little bit. The rpm at neutral is also lower than before, it is at 800 now. My old plugs were in really bad shape. so I need to replace them anyways. These plugs will last a long time, probably till the rest of my car's life. They are worth the money.
Lo-Fi Version Time is now: April 24th, 2025 - 3:14 AM
