> st205 egr deactivation ... some questions?!?!
post Apr 1, 2004 - 4:11 AM
djr97
Joined Mar 25, '04
From Germany
i have studied all available sources and know about the basics of egr deactivation smile.gif but i still have some questions:
1. is it sufficient for deactivation to just cut and block the hose between actuator and egr-valve? or do i have to use those block plates some shops are selling?
2. there are people saying that a non-functioning egr can destroy the cat (burning caused by too high temperatures). is that true with the metal cat on my st205?
post Apr 1, 2004 - 1:39 PM
kuya1284
Joined Nov 15, '02
From Corona & Vallejo, CA
QUOTE (djr97 @ Apr 1, 2004 - 2:11 AM)
I didn't realize that Euro ST205's had an EGR system.
post Apr 1, 2004 - 1:44 PM
qatar11
From Lake Orion, MI
agreed, what EGR?
And the problems with EGR is that on OBDII or later cars, the failure of the EGR system will set your fuel maps to a defualt, "limp" mode, and so more creative means to fake the ECU are required.
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Apr 1, 2004 - 2:26 PM
uzthedentist
Joined Mar 21, '04
From united kingdom
i think hes talking about the vsv. if so yes cut the pipe and block both ends with a bolt and jubilees, but the wuestion is why do you want to do this? are you fitting a boost controller?
GT4 ST205 79 modifications and rising!!
spec list: http://sox-japoc.co.uk/forum/garage.php?mo..._vehicle&CID=10
post Apr 1, 2004 - 4:12 PM
djr97
Joined Mar 25, '04
From Germany
no, doesn't have anything to do with the vsv!
since uk-celicas are jdm-imports they might not have an egr - at least japanese models don't have one!
german models have egr and i would like to cut it off because the engine should run smoother and cleaner without it.
post Apr 1, 2004 - 4:40 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
so does that mean if u can get your hands on a clip from europe with egr u could pass inspection?
Team 6gc 2005
Lo-Fi Version Time is now: November 28th, 2024 - 12:50 PM
