> Have a clunking rear end?
post Apr 2, 2004 - 12:26 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
WEll, like a couple guys said..Its probably the sway bar bushings!! I bought two of them from advanced auto for 4.62 each and it took me about 5mins to replace them...the old ones werent broke or anything but the rubber was hard and kinda wore out. Anyways, that fixed my clunking noises.
post Apr 2, 2004 - 12:57 PM
aaronc222
Joined Sep 22, '02
From Detroit
Any chance you have part numbers? I went to Advance this morning and they had the links, but not the bushings. The links were 23.99 for the front and 49.99 for the rear.
post Apr 2, 2004 - 8:06 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
they have them there...they will have to order them..
TRW HB1180
Sway Bar Mount Bushing
4.29 each
post Apr 2, 2004 - 10:06 PM
aaronc222
Joined Sep 22, '02
From Detroit
Thanks, I'll probably get those next week.
When I pulled the tires off the front, I noticed the front links looked pretty nasty, so I decided to change the front links. The car handles like new, it got rid of most of the body roll.
Part # for the front link is 18186. It's also by TRW, and it's the same part for both sides. Only took about 15 minutes per side.
post Apr 22, 2004 - 1:09 PM
94silverst
Joined Feb 20, '04
From Washington
Hey could someone post a link to that site?? I can't find it!!
post Apr 22, 2004 - 2:06 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
www.partsamerica.com is advanced auto's website
This post has been edited by bufferdan: Apr 22, 2004 - 2:06 PM
post Apr 26, 2004 - 8:44 AM
CelicaQT
Joined Sep 29, '02
From Sterling Heights, Michigan
Could someone post a pic of what this bushing looks like?
Is this just the "black" rubber portion with the bolt enclosed in it?
This post has been edited by CelicaQT: Apr 26, 2004 - 9:09 AM
post Apr 26, 2004 - 9:28 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
Look like this..the sway bar runs through both of them and there is a bracket that goes over them and bolts to the frame with two bolts.
post May 11, 2004 - 12:05 PM
I got this clunking also, can anybody confirm if the part #s are the same and the setup is the same as the coupe?
post May 11, 2004 - 12:10 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
check you're sway bar links they could be shot
This post has been edited by defgeph: May 11, 2004 - 12:10 PM
I will return one day.
post May 11, 2004 - 12:17 PM
CelicaQT
Joined Sep 29, '02
Ok one last time...these bushings in that picture, are they the ones that are at the top and bottom of the sway bar link?
I was told from a AutoZone Rep. that you can't just replace those, and that you'd have to replace the whole stabalizer link?
This post has been edited by CelicaQT: May 11, 2004 - 12:21 PM
post May 11, 2004 - 12:20 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
sway bar links attach the sway bar to the rear struts. the sway bar bushing are pictured above are attached to the frame of the car.
This post has been edited by defgeph: May 11, 2004 - 12:21 PM
post May 11, 2004 - 12:27 PM
CelicaQT
Joined Sep 29, '02
lol guess I gotta go look under my car again. lol
post May 11, 2004 - 8:39 PM
c-note
Joined Mar 23, '04
From RI
is it a clunking or a ticking? I have a weird noise only when I turn very hard to the right ...any ideas?
-C
post May 12, 2004 - 9:38 AM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
the bushings are the same for coupe and hatch.
post May 12, 2004 - 12:48 PM
i have an annoying clunking, its horrible.
post May 12, 2004 - 1:37 PM
3FingersCelica
Joined Aug 21, '03
From Endicott NY
I just bought some from autozone they were $11.99 a piece
post May 12, 2004 - 4:02 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
yeah..you shoulda went to advanced auto. At autozone they sell the rubber bushings with the metal brackets. All you really need is the rubber bushings for 4$ each
post May 12, 2004 - 10:49 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
Just FYI, but if you're able to measure the bar, you might be able to find some Energy Suspension urethane bushings that will fit int he stock location. They would be firmer than the stock rubber bushings, and might last longer. Urethane has a tendency to squeak after the lubricant degrades or is lost...
post May 25, 2004 - 4:57 AM
xeril
Joined May 24, '04
From state of northern virginia
QUOTE (c-note @ May 12, 2004 - 1:39 AM)
-C
more info please? what does it sound like? how hard do you have to turn? only occurs when turning right? how about hard cornering?
Lo-Fi Version Time is now: January 12th, 2025 - 12:31 AM
