> Wiring Diagrams, For security etc
post Apr 5, 2004 - 12:29 PM
Pali_playa
Joined Apr 4, '04
From VA, USA
DISCLAIMER: This wiring information is being provided on an "as is" basis, without any representation or Warranty. Is is your responsibility to Verify the wires by testing them
With that said....Lets get goin
FYI: You will not need all the wires that I post, read your instructions
ADMIN: please sticky this
This post has been edited by Pali_playa: Apr 5, 2004 - 1:06 PM
post Apr 5, 2004 - 12:43 PM
Pali_playa
Joined Apr 4, '04
From VA, USA
1994 Toyota Celica
Item Wire Color Polarity Wire Location
12V White- Brown/Red + Ignition Harness
Starter Black/White + Ignition Harness
Ignition Black/Orange + Ignition Harness
Second Ignition Blue/Red + Ignition Harness
Accessory Gray + Ignition Harness
Power Lock Blue/Back - Lock Module right of column
Power Unlock Blue and Green *1 - Lock Module right of column
Parking Lights + Dk. Green At Dimmer
Parking Lights - Lt. Green Steering Column
Headlights Red/Black - Steering Column
Door Trigger Red/White - Drivers Kick Panel *2
Trunk/Hatch Pin Red/Green - Drivers Kick Panel *2
Tachometer Gray Check Connector
Brake Wire Green/White + Driver Kick Panel
Horn Trigger Green - Steering Column
LF Window up/down Green - Red Drivers Door Switch
RF Window up/down Grn/Wht - Red/Blu Driver Kick Panel
LR Window up/down
RR Window up/down
*1 Use both wires and diode isolate each.
*2 Door and trunk trigger looped out of main harness heading towards rear
of car, almost directly below door hinge wrapped in beige tape
This post has been edited by Pali_playa: Apr 5, 2004 - 12:58 PM
post Apr 5, 2004 - 1:00 PM
Pali_playa
Joined Apr 4, '04
From VA, USA
1995 Celica
12V White- Black/Red + Ignition Harness
LR Window up/down Grn/Wht - Red/Wht LR window switch
RR Window up/down Green - Red RR window switch
post Apr 5, 2004 - 1:06 PM
Pali_playa
Joined Apr 4, '04
From VA, USA
1996-1999 Toyota Celica
Power Unlock Blue and Green *2 - Lock Module right of column
Door Trigger Red/White - Drivers Kick Panel *3
Trunk/Hatch Pin Red/Green - Drivers Kick Panel *3
Tachometer Gray Check Connector *1
*1 On the 2.2 motor go to the ignitor on the rear drivers side of the engine compartment
*2 Use both wires and diode isolate each.
*3 Door and trunk trigger looped out of main harness heading towards rear
post Apr 6, 2004 - 11:51 AM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
sticky this
post Apr 7, 2004 - 3:29 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
awesome. I can put in the viper alarm this weekend!
post Apr 9, 2004 - 1:59 PM
BigEdge169
Joined Nov 18, '02
From Texas
I've got a wire diagram of the gauge wires also in case anyone is wanting to make a custom gauge cluster (like I hope to do this summer). You can use the diagram to keep all the warning lights, blinkers, ets. If anyone needs it just let me know and I'll scan it and send it to you.
post Jun 24, 2004 - 2:33 AM
creis
Joined Jan 10, '04
From Shoreline, WA
note for those replacing a stock alarm in a 94 gt:
Its under the seat, and the harness that its connected to needs to be fixed in order to install a new alarm, and its easy. just unplug it, and cut off the plug, then look at all the wires, and connect the ones that are the same color, white/black with white/black etc. the old alarm uses a braker kinda thing to shut off surton things when the alarm gose off. this allows you to wire up a new one under the dash using the above listed wires rather then putting a new one under the seat.
note: the colors do not match up, the ones listed above are correct but not the same as the ones under the seat, and there is no diagram for the ones under the seat.
post Jun 28, 2004 - 1:44 PM
lantz2121
Joined Jun 27, '04
From ohio
I am in need of help!!! I am looking for someone or a company that will splice a wiring loom from a 7asfe to a 3sgte 3g. if anyone knows where i can find this info please contact lance at lantz2121@yahoo.com thanks
post Sep 29, 2004 - 8:35 PM
does anybody know the wires for the power mirrors?!? 96'
post Feb 6, 2005 - 12:05 AM
Jaws4God
Joined Mar 27, '04
I just installed a Viper Alarm and I wanted to thank you all on here for the information. I was able to read about wiring diagrams, how to's and images that helped me and my dad figure it all out.
Thank You!
Special thanks to Coomer and Pali_playa for the wire listings and instructions.
This post has been edited by Jaws4God: Feb 11, 2005 - 9:57 PM
post Feb 16, 2005 - 6:12 PM
lord_of_anime
Joined May 10, '04
From Australia
QUOTE(Jaws4God @ Feb 6, 2005 - 5:05 AM)
Thank You!
[right][snapback]242549[/snapback][/right]
would it be OK for you to forward that wiring diagrams to me?
me and a friend of my would be trying to install a new alarm system in my 98 G6. This would be our first Attempt and any help would be greatly appreciated.
my e-mail is "lord_of_anime@yahoo.com"
post Apr 11, 2006 - 1:41 AM
hmongtaejien
Joined Apr 7, '06
From Fontana, CA
does anyone know where the tachometer wire is located on a 95 ST?
post Oct 26, 2009 - 12:00 AM
nammer
Joined Aug 22, '07
From Burnaby, British Columbia, Canada
I was wondering if this information is relevant to GT-4's?
If not, does anyone have information on wiring for a 1994 GT-4?
post Jan 19, 2011 - 2:56 AM
Needles
Joined Nov 18, '10
From montreal
i know its old but here the info , all wiring diagram for celica gt-four 3th gen
http://gtfour.supras.org.nz/diagrams.htm
enjoy
post Dec 22, 2012 - 11:16 PM
S8S8
Joined May 9, '09
From Brisbane, Australia
QUOTE (creis @ Jun 24, 2004 - 5:33 PM) *
Eight years since this original post, has anyone managed to come across a wiring diagram for a 94 with the under seat alarm?
post Apr 24, 2015 - 11:54 AM
Poonicus
Joined Apr 24, '13
From Tomball, TX
Necro bump.
Does anyone know where the alarm brain is in a '96 convertible? It's not under the seat and i dont want to go tearing through the dash if i don't have to.
"As a professor of science, I assure you we did, in fact, evolve from filthy monkey-men." -Prof. Farnsworth
post Aug 3, 2015 - 11:34 AM
6gCelicaowner
Joined Jul 29, '15
From Utah
Does anyone know how to trouble shoot specific wiring problems??
post Aug 3, 2015 - 11:39 AM
6gCelicaowner
Joined Jul 29, '15
From Utah
QUOTE (Poonicus @ Apr 24, 2015 - 11:54 AM) *
Necro bump.
I just took my drivers side dash out under the steering wheel because I saw some cut wires just dangling, they were aftermarket connections that were spliced halfass into the original . I also noticed a lot of piggy back connectors up near the fuse block and since my car has no alarm on it I am gonna say that the alarm once was housed in that area directly under the steering wheel, theres lots of room for it.
Lo-Fi Version Time is now: November 24th, 2024 - 4:21 PM
