> updates on the Celica
post Apr 6, 2004 - 3:10 PM
Phat_99CeliGT
Joined Aug 30, '02
From Ohio
well, after 2 weeks of trying to get a tracking # from the seller, my Z3 sides finally arrived.
i put them on the Celica, and guess what?
THEY DON'T FIT FOR ****!!!
I have about given up on this damn car.
Im gonna track some people down and get some cash and have someone fit the kit.
Im still painting it, but im not gonna fit it.
I still have alot of work ahead of me.
i need to get someone to fit the front, fenders, sides, and rear bumper.
Im getting my new valves installed thurs morning.
im trying to find someone to do my seats.
Im getting help on my custom sub enclosure.
then im painting it myself
Jared Harwell
post Apr 6, 2004 - 3:35 PM
post Apr 6, 2004 - 3:38 PM
aznxrussel
Joined Oct 22, '02
From irvine
i didnt know they made z3 fenders
post Apr 6, 2004 - 5:54 PM
initialdrift55
Joined Sep 23, '03
From Miami,FL
yea not to be rude or anythin but do a search aznxrussel and put z3 fenders and there has been a bunch of posts and you'll find some cars with pics of them i believe www.procarparts.com sells them and cheap too.
post Apr 6, 2004 - 9:19 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
damn, your car gonna be done by june 19th?
- Ryan
aim: rkgreen04
post Apr 6, 2004 - 9:24 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Where are you fitting problems? Was everything tighten for the photo. I saw the gap on the front spoiler, but wasn't sure if it was bolted down. Overall your car looks really good. What color are you going to paint it?
post Apr 6, 2004 - 9:36 PM
Phat_99CeliGT
Joined Aug 30, '02
From Ohio
im praying it gets done by june. if not painted, it will at least be put together. Im only waiting on my sides to come in from ViS.
i took it all apart and started again on fitting it. i got a lil closer to the front bumper then it is in the pics. the inner wheelwell is what im getting mad at, i might just pull it for good.
everything is bolted down in the pics. right now there is a 1/2"-1/4" gap between the fenders and the front bumper.
im gonna get it all bolted on and get it on a trailor and take it somewhere to get it fitted.
When/IF its finished, its gonna be a candy red with gold pearl.
Jared Harwell
post Apr 6, 2004 - 10:40 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
why did you change from what you had?? I offence to what your doing, but i liked the look before better.... not a fan of the fenders or front end... An also it was finished right?? well good luck
post Apr 6, 2004 - 11:33 PM
95STHATCH
Joined Jun 21, '03
From FRANKFORT,KENTUCKY
Was it hard to fit those 5th gen mirrors. If your car gets finished I think it will look good. I like the sound of the paint job.
post Apr 6, 2004 - 11:44 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
Lookin good man! you dont have too much of a fitment issue.. I would take the tire well out though.. It will make that alot easier to do.. also you might wanna mess around with where your mounting holes are on the front of the fender.. you can do alot of moving around there.. also there are two little weldin in screws on the front corner.. make sure there sitting right.. I had mine off an it caused me a buncha problems, dont get frustrated man.. it takes time to get things right sometimes.. hell Ive been working on mine for 2 years plus now wink.gif
edit: also on your invader front make sure you have that bottom section of your kit under the bottom of the lowwer support beam.. that can hang up there and cause problems.. you might need to remove all of your under cover pieces if you havent already done so.. also you have a FMIC correct? if so maybe try triming some of the section that comes into on the big center section where the IC is.. if its touching then it might make it so where the bottom of the front wont come back far enuf - hope you understood that - LOL
This post has been edited by NEVERSTOP: Apr 6, 2004 - 11:48 PM
post Apr 7, 2004 - 8:24 AM
Phat_99CeliGT
Joined Aug 30, '02
From Ohio
I WISH I HAD A FMIC!!
lol
i don't have one though.
The holes on the fender, r u talking about the place where it bolts to the top? Thats really the only spot that i have to deal with now. the hood won't close, so if i round out the holes, u think it would line up better?
i did trim off some of the invader. the piece u were talking about that tucks under the support, i cut it off. if u can see in the pic, its flush along the back. I tried to tuck it under, but since im putting mesh in, i wanted it to look a lil better.
Jared Harwell
post Apr 7, 2004 - 10:54 AM
Isnt your kit Vis? My Invader front end had the mesh already installed.
This post has been edited by Supersprynt: Apr 7, 2004 - 10:55 AM
post Apr 7, 2004 - 11:13 AM
Phat_99CeliGT
Joined Aug 30, '02
From Ohio
nope its not.
i thought it was, but shouldn't there be a ViS sticker on the inside of the bumper?
Mine didn't have it.
Jared Harwell
post Apr 7, 2004 - 12:28 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
I was talkin about the mounting point kind of infront and below the low beam headlight.. there are two small weldin in bolts pointing up and the fender should hook onto them... your hood not closing is also a problem.. you might wanna address that 1st.
post Apr 7, 2004 - 1:11 PM
Einhander
Joined Oct 23, '03
From ky
Thats odd that your Z3 have bad fitment. Mine fit fine, except for my hood being warped. . i had to push down on it to get it close, The only other problem area was the inside fender bolt behind the wheel did not line up, but with a little push it was good enough to get the bolt through. After i finish with molding of the combat kit i'll get the pic's up of the complete install.
post Apr 7, 2004 - 2:14 PM
Phat_99CeliGT
Joined Aug 30, '02
From Ohio
QUOTE (NEVERSTOP @ Apr 7, 2004 - 10:28 AM)
i got that, i took the bracket off and slipped it over the studs on the fender, carefully pulled it back and bolted it down.
all i have to do is bolt under the door, and its all bolted down.
Jared Harwell
post Apr 7, 2004 - 2:30 PM
Who did you order from?
I ordered from ViS directly I didnt have a sticker. Although mines still in the bubble wrap?
post Apr 7, 2004 - 2:54 PM
Phat_99CeliGT
Joined Aug 30, '02
From Ohio
i got mine off a 6gc member.
Jared Harwell
post Apr 8, 2004 - 7:09 PM
nik
Joined Sep 30, '02
you can fix the fenders yourself its not hard the main thing that was off on my fenders was that bracket that bolts next to the middle of the door i had to heat gun that the rest was no prob just a little widing two holes on top and finished.if you need any help e-mail me
This post has been edited by nik: Apr 8, 2004 - 7:10 PM
post Apr 8, 2004 - 7:26 PM
mine is kinda weird on fitting, the gap between the fender and the door is off, its bigger up at the top and smaller at teh bottom plus i think the fender needs to come out a lil more at the top by the door too
Lo-Fi Version Time is now: February 22nd, 2025 - 3:37 AM
