> Performance on 94 GT with stock 5F-SE, Average performance with stock 5F-SE
post Apr 7, 2004 - 4:32 PM
grap
Joined Apr 7, '04
From Menomonie, WI
I bought a 94 Celica GT last year and fell in love with the car. However, one of the things that has been annoying me is the engine seems to crap out at around 4500 – 4800 RPM. The specs for the engine I have seen have it putting out peak HP at 5400. I am going to have some engine work done and wondered if I should have this looked in to or is this par for the course.
This post has been edited by grap: Apr 7, 2004 - 8:13 PM
post Apr 7, 2004 - 8:44 PM
sinner96ST
Joined May 15, '03
From Aurora IL
QUOTE (grap @ Apr 7, 2004 - 2:32 PM)
I dont think that's really a problem, US spec 6gc's often have little to offer on the top end, unless you're gonna boost. I believe the torque pretty much gets you there, and the lack of horsepower really shows on the top end.
post Apr 10, 2004 - 1:07 AM
RedGT4
Joined Apr 9, '04
From suffield CT
actully the 5sfe takes very well to headwork. but for more simple bolt on parts that will open up the top end a bit. get an intake, header, exhaust, should give you an awsome 8whp..(least from the dynos from NA mr2's same engine though) but it gives you a broader powerband. opens up the top end a bit.
post Apr 10, 2004 - 2:26 AM
grap
Joined Apr 7, '04
From Menomonie, WI
QUOTE (RedGT4 @ Apr 10, 2004 - 6:07 AM)
What type of "headwork" are you refering too? I am planning to have the head gasket replaced and a valve job so far.
post Apr 10, 2004 - 5:55 PM
RedGT4
Joined Apr 9, '04
From suffield CT
talking like port and polish and new cams. a mabye a Slightly bigger valve.
This post has been edited by RedGT4: Apr 10, 2004 - 5:56 PM
post Apr 10, 2004 - 11:54 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (RedGT4 @ Apr 10, 2004 - 10:55 PM)
No... just port/polish/gasket matching, etc... Cams/valves/valvetrain would be a step up from that. A head gasket and valve job is mostly maintence, replacing head gasket, refinishing the surface, reseating the valves, it's all maintence associated with a headgasket/valve job. It might slightly increase performance depending on how it's done...
post Apr 12, 2004 - 4:30 PM
saleeka
Joined Sep 4, '03
From Twin Cities MN
hey do you think the dealer could do a port polish when they fix a headgasket, and balpark price if they do?
post Apr 13, 2004 - 1:34 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (saleeka @ Apr 12, 2004 - 9:30 PM)
No... dealers don't modify stock parts (unless it's something they cover under warantee)...
Lo-Fi Version Time is now: November 28th, 2024 - 9:42 AM
