Clicking noise from front drivers side, any ideas what it could be? |
Apr 12, 2004 - 1:14 AM |
Enthusiast Joined Feb 13, '03 From California Currently Offline Reputation: 2 (100%) |
to check if its you wheel bearing, take the tire off, then the brake caliper, then the rotor. wiggle the wheel hub if there is excessive play then its you bearing for sure, and in my opinion those are a b*tch to change if the bearings are frozen. also while youre there check those boots make sure theyre not ripped
-------------------- 2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3 gone but not forgotten 2008 Space Grey BMW Z4 ///M 2009 Black Honda Civic LX Coupe 2006 Magnetic Black Nissan 350Z 2007 Crimson Red BMW 335i Coupe |
Apr 12, 2004 - 2:07 PM |
Enthusiast Joined Mar 2, '04 From Louisiana, USA Currently Offline Reputation: 2 (100%) |
They can indeed be difficult to change. If you don't have easy access to a press, just have a shop remove and install the new bearings. Once I get a good host for my pics, I'll write up a thread with my experiences. |
Apr 12, 2004 - 2:25 PM |
and if you do decide to change those bearings without a press, please be very carefeul to not damage any part of the housing, a scratch or dent will possibly ruin it
Apr 12, 2004 - 9:15 PM |
Enthusiast Joined Sep 28, '03 From UK Currently Offline Reputation: 0 (0%) |
so wheel bearings can be a possible cause for these clicks hmmmmm
Apr 14, 2004 - 6:36 PM |
yes they are a possibility
May 18, 2004 - 8:50 AM |
BOUNCE -
well replaced whole drive shaft on the drivers side bu ticking still occuring but have recently have noticed that the ticking goes away whenever i dip the clutch any ideas what it could be? the ticking is becoming increasingly irritating!!!!! |
May 18, 2004 - 1:22 PM |
did u check ure wheel bearing?
This post has been edited by fastgt: May 18, 2004 - 1:23 PM -------------------- 2011 Spice Orange Mini Cooper
May 18, 2004 - 2:23 PM |
Enthusiast Joined Jul 12, '03 From Chatham, Ont Currently Offline Reputation: 0 (0%) |
Sounds like an axle. I have had that happen twice and both times it was an axle. The boot tears and it kills them pretty quick.
May 18, 2004 - 5:51 PM |
but the ticking sound goes away when i dip the clutch surely it cant be the axle???? fastgt - yeah checked wheel bearings and mechanic said nothing wrong |
May 20, 2004 - 10:03 AM |
Enthusiast Joined May 5, '04 From Cary, NC Currently Offline Reputation: 0 (0%) |
I have to take my car to toyota dealer and get it checked...to see whts wrong with it....so it makes it easier for u too know!!! my dealer charges about 59 bucks for the check up
May 21, 2004 - 1:47 AM |
toyota going to run checks on the whole car for $59? or just to identify what could be the cause for the ticking???
ive been meaning to take my car to a mechanic so he can perform a full car diagnostic to see whats wrong and whats need replacing but not sure what sort of money i should be paying, any ideas guys? This post has been edited by veilside: May 21, 2004 - 1:48 AM |
May 21, 2004 - 7:14 AM |
wow that to much stuff to check to see if your bearing.. just jack up the car and take on hand on the wheel and put it on 2o clock.. and the other hand at 6o clock.. and push on hand and pull the other one..... if the wheel wiggles.. then yea you need a new bearing -------------------- |
Lo-Fi Version | Time is now: November 27th, 2024 - 6:00 PM |
