Help with dash panels, Removing driver side vent and center con |
Apr 10, 2004 - 1:21 PM |
Enthusiast Joined May 23, '03 From Illinois Currently Offline Reputation: 0 (0%) |
How do i remove these dash inserts? The driver's vent has a small light that i don't know how to remove. Also how do u take out the cigarete lighter?
Thanks |
Apr 10, 2004 - 4:02 PM |
Usually i start at the back of the shifter boot, lift that up. And then you can lift the rest of the center console. It just snaps in and out.
Apr 10, 2004 - 9:16 PM |
How do u unplug the lighter? I don't want to tear any wires?
Apr 10, 2004 - 9:22 PM |
It just unplugs. Its an L shaped plug.
Apr 11, 2004 - 10:15 AM |
How about the driver side vent? Got any tips?
Apr 11, 2004 - 10:34 AM |
Enthusiast Joined Sep 5, '03 From Grapevine, TX Currently Offline Reputation: 0 (0%) |
S
E A R C H I've answered this same question about 6-7 times. The SEARCH button is your good, good friend. -brian |
Apr 11, 2004 - 4:48 PM |
i have searched a couple of times but i still couldn't find an answer to how to remove the bulb on the driver side vent.
Apr 11, 2004 - 4:56 PM |
Bulby? Ehhh.. mine doesn't have one, and I've never seen one with a bulb either. Hrmm, do you have the vent itself extracted and the wire (leading to the bulb) taken out? Most of the items in our dash (center piece at least) clip on the back and can be removed by taking your time and using fingernails to pry it loose (center air vents, hazard light button), and some have small screws (clock), so look for something like that. If you don't have the wire off yet, every wire I've seen either pulls right out, or unclips in some way. The first time I took off my center piece I had no problem removing anything (wire-wise), but the second time I completely forgot how to take off the white-tipped wire and almost ripped it out. Just mess around with the clips/plugs/screws, you'll figure it out. The worst you could do is break it. And in that case, you'd just have to go to a junkyard and find a replacement. Oh no. $10. Damn.
-brian |
Apr 11, 2004 - 5:57 PM |
The bulb that i was talking about is the really small one on the driver's air vent. The one that tells you that the alarm is on.
Apr 11, 2004 - 6:19 PM |
Enthusiast Joined Aug 30, '02 From North Carolina Currently Offline Reputation: 0 (0%) |
that light thing is wierd. what i do to pop it out is just get a flat head screw driver and pry it out. be careful not to mess up your dash though. then it should have a plug or something connected to the light ( i would think).
adam -------------------- MISS THE CELI, BUT...
Apr 13, 2004 - 11:13 AM |
i dunno i still can't figure it out. I'll try to post a pic so u can c what i'm talking about.
Lo-Fi Version | Time is now: January 10th, 2025 - 1:32 AM |
