Stroker Kit to tha..., whut whut |
Feb 9, 2003 - 2:56 AM |
Enthusiast Joined Oct 1, '02 From Minnesota, USA Currently Offline Reputation: 0 (0%) |
Yeah.
I was looking for some custom engine parts, like to make the 5sfe, to those of who own a celi with that engine, go better, run smoother, and have the ability to take more horespower. I got tha ansa! February/March of 2003, Import Performance Parts, a division of Flatlander Racing, is coming out with a Stroker kit for our engines! The kit will include the following: - Forged Crank (w/Knife-Edging option) - Custom Forged Pistons (any compression and bore) - Forged Steel Pins (ultra-lites available) - Piston Pin Locks - Plasma Moly Racing Rings - Forged 4340 Steel or Billet Rods - Main and Rod Bearings Which basically means more horsepower, torque, and a better ability to handle even more horsepower if you decide to run Nitrous or Turbo or whatever you want. I will email them and tell them I want to know prices. You guys can all check out their website... http://www.importperformanceparts.net Lata! -------------------- 95 Toyota Celica GT
Feb 9, 2003 - 4:57 PM |
Enthusiast Joined Jan 9, '03 From Concord, NC Currently Offline Reputation: 0 (0%) |
Myfriend told me about that, and I think he said it was between 1500 and 2k. I got so jacked about it, it just makes it more confusing to do that and slap a turbo in after or just get the 3S swap. JESUS!
Feb 9, 2003 - 6:51 PM |
Enthusiast Joined Oct 27, '02 From Barbados Currently Offline Reputation: 0 (0%) |
igotta5S-FEturbo!
The 5S compression of 11:1 sounds wrong. It should more be in the range of 9.5:1 http://www.toyotacelicaonline.com/5sfestats.htm 5S-FE Engine Stats Engine 2.2L four EFI DOHC Horsepower 1994-95 135HP@5400RPM 1996-98 130HP@5400RPM Torque 1994-95 145@4400RPM 1996-98 145@4400RPM Bore 3.43 in Stroke 3.58 in Compression ratio 9.5:1 This post has been edited by west_minist: Feb 9, 2003 - 6:57 PM -------------------- West_Minist
Hydra EMS Dealer & Tuner Subaru ECUFlash Tuner http://www.socob.bb http://xtremeracingtuning.com Viciously Tuned, Driven Hard |
Feb 9, 2003 - 6:57 PM |
Feb 9, 2003 - 6:59 PM |
While I was editing, you got in a post.
I forgot that it is some what lame. 10 would be nice, but you might have some detonation problems. -------------------- West_Minist
Feb 9, 2003 - 8:05 PM |
Enthusiast Joined Oct 1, '02 From North Bethesda, MD Currently Offline Reputation: 0 (0%) |
that kit will kick the compression to 10.5:1 which will not be a good platform for a turbo, so if you want that, go 3sgte... if you want a kickass 5sfe with a lot of torque, you can use this kit. -------------------- 1994 Lexus ES300
1989 Supra Turbo 1990 RHD ST185RC - JDM Spec |
Feb 9, 2003 - 8:22 PM |
it would be good depending on how much boost the kit is design for.
Maybe the kit will be doing 6-10psi. I know that the 4AGE 20v Silver top with 11:1 or something like that can hold onto 8psi fairly good. Even up to 10. Well as you stated, it is best going with the 3SGTE swap. There are alot of rewards in that choice. |
Feb 9, 2003 - 8:29 PM |
Enthusiast Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) |
Jun makes a stroker kit for the 3sgte... but its like 3.5k for the damn thing... that would be my route over a stroker kit for the 5sfe
-------------------- 99 project version 3.0.. hello SEMA 2010 =) |
Feb 9, 2003 - 9:09 PM |
i believe that the kit is made for NA, not boost. i didn't see anything about turboing the stroker kits on the site. -------------------- 1994 Lexus ES300
Feb 9, 2003 - 11:45 PM |
Well, even the 3sgte can't handle too much. If you want to go over the 350hp mark, it's highly recomended to get JE Forged Pistons and Pauter Rods. I added these parts yesterday to the parts database and hopefully Coomer cna have them up soon.
Feb 9, 2003 - 11:51 PM |
AND BTW...
I was just trying to add something else to the puzzle and choices that us Celica owners have. Maybe the 3SGTE is better idea for SOME people, but people who don't want to hassle with swapping and want to keep their 5SFE engine....I'm offering another option for those people. -------------------- 95 Toyota Celica GT
Feb 10, 2003 - 6:48 AM |
Ok.
I haven't check out the site. |
Feb 11, 2003 - 1:56 AM |
it says you can have your choice of compression ratio, so get the kit at a nice 8.5:1 to 9:1 head compression and get the burien turbo kit installed at the same time and you got some nice engine mods set with a nice level of boost.
Feb 12, 2003 - 12:46 AM |
Enthusiast Joined Nov 8, '02 From Bel Air, MD, USA Currently Offline Reputation: 0 (0%) |
So what will this kit give a 5fse? More horsepower and torque? How much hp and torque? Is it worth doing if you dont plan on turbo and nitrous? What if i just want one kick ass powerful 5fse engine thats all power with out turbo?
And where are you guys getting $2K from on the site for the major kit is says and i quote: "contains complete gasket set, set of pistons and rings, main bearings, rod bearings, thrust washers, timing belt, balance shaft bearings (if applicable), and a set of expansion plugs (does not contain camshaft, timing kit or oil pump). Pistons & Rings: Std., .020, .040. Bearings: Std., 10, 20, 30." EKTO25M $279.00 This post has been edited by PaulGT: Feb 12, 2003 - 12:59 AM |
Lo-Fi Version | Time is now: November 24th, 2024 - 10:43 AM |
