Son of a Bish, ...Starter troubles |
Apr 14, 2004 - 11:50 AM |
Enthusiast Joined Nov 26, '03 From McKenzie, TN Currently Offline Reputation: 0 (0%) |
Ok...I went to leave for school this morning, got in my car and cranked it. I noticed some sort of noise that sounded like it could be my belt squeaking really bad, which had never happened b4. I raised my hood and looked around (w/ my car still running). After a while it began smelling hot and then I saw some smoke coming up. HOLY S*** my car's dying...so I try turning it off. I turned it completely off and took the key out of the ignition. The car just keeps trying to crank itself. By now I'm kinda freaking out. I figured out my starter wasa stuck, so I pulled my battery cable off and that stopped it, but as soon as I touched the cable back to the terminal it starts trying to crank itself again. Finally I just called my dad to get it fixed and drove my Bronco to school. I may have to get a new starter. I'll keep you guys posted on it and if I ever get it fixed and can get to a camera, I'll get some pics up of the stuff I've done to it over the last few months.
Apr 14, 2004 - 11:46 PM |
Enthusiast Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
sounds like something shorted itself out.
-------------------- Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Apr 15, 2004 - 1:45 AM |
Enthusiast Joined Nov 6, '03 From Campbellsville, Ky. Currently Offline Reputation: 0 (0%) |
You might want to check your ignition switch along with the starter, my old Honda Civic did about the same thing, by the time I got pulled over and stopped, about half my engine compartment wiring harnesses had melted and were sending fire through the vent holes in my hood. The ignition switch kept sending a hot signal to the starter solenoid which finally got so hot it melted the wiring and started a fire underneath my hood, and the whole time the starter never tried to engage.I had to replace the 2 main wiring harnesses, the battery cables, the starter, the ignition switch, and the battery. It was a complete nightmare, I hate electrical fires on a car.
So definetly have the ignition switch checked out before you burn out another starter. This post has been edited by gas65: Apr 15, 2004 - 1:46 AM |
Apr 17, 2004 - 3:00 PM |
Enthusiast Joined Jun 10, '03 From FL Currently Offline Reputation: 0 (0%) |
i had a problem like this. im driving a early 90's camry since my car is down. and the ignition coil went out. so i jacked the one off my celli
Apr 20, 2004 - 11:41 AM |
Well I finally fixed the prob yesterday. Had to buy a new starter($110) plus pay a guy i know $50 to change it out for me. Now that I watched him I shouldve just done it myself, but I wanted to be sure it was done right so...there goes some $. Oh well, having my celi running again is worth it, so now I can get back to driving it and modding it. I'm sooooooooo happy.
Apr 27, 2004 - 10:51 PM |
where did you get the starter ?
Apr 28, 2004 - 10:51 AM |
auto zone
Lo-Fi Version | Time is now: November 23rd, 2024 - 5:31 PM |
