> whats better? 3S-GTE swap or 5S-FE turbo kit, need some opinions
post Apr 14, 2004 - 6:34 PM
droptopGT
Joined Apr 12, '04
From Nj Team 6gc
Team 6gc 2oo5
post Apr 14, 2004 - 6:38 PM
LatinKraze
Joined Oct 22, '03
U get more power from 3SGTE. But it comes down to preference IMO.
post Apr 16, 2004 - 10:46 PM
Mousetrashdiver
Joined Dec 21, '03
From Houston, TX
It really matters how many miles you have on your motor, me i cant turbo mine its to old, if i did turbo charge mine it would be really good the first time but thats all i would get it would blow my motor.
besides you will get FAR FAR more HP for a 3sgte
post Apr 17, 2004 - 6:36 AM
Sirius
Joined Apr 15, '04
From United Kingdom
I am biased but you'll also get out of the box reliability from the 3S-GTE.
post Apr 17, 2004 - 6:54 AM
a 5sfte will not be as reliable as a 3sgte.
post Apr 17, 2004 - 9:07 PM
1bwilson
Joined Aug 30, '02
From Maryland
With a proper 5sfTe setup it will beat a stock 3sgte psi for psi.
With that said a built 3sgte can create alot of Hp also.
If you have the money and time the BEST setup you can do it the 5sgTe. 5sfe bottom end (Built for boost) and a p&p'ed race preped 3sgte head. A setup like this will create a stroked 2.2l 3sgte. Look forward to spending close to 5k to get it all running smooth.
Member of Team 5sfTe
post Apr 17, 2004 - 9:10 PM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
You sure about that??A highbred 5s might have more power psi for psi, but stock I doubt it..
Besides a 3sgte can handle more psi without modification. 3sgte is more practical.
This post has been edited by Uppitycracker: Apr 17, 2004 - 9:12 PM
post Apr 17, 2004 - 9:21 PM
1bwilson
Joined Aug 30, '02
From Maryland
Thats why I said "proper" 5sfTe and "Stock" 3sgte.
The 5sfTe is a torgue monster and laydown (Proven by Mike dodson) 200hp and 238tq to the wheels with only 9psi. The 3sgte puts at the crank 200hp 200tq running the stock 12psi.
post Apr 17, 2004 - 9:40 PM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
QUOTE (1bwilson @ Apr 17, 2004 - 7:21 PM)
Nice, it just sounds wrong I guess tongue.gif Do you know more about mikes setup? Like did he do alot internal and head work and what not or is it just basically the turbo?
post Apr 17, 2004 - 9:52 PM
QUOTE (1bwilson @ Apr 17, 2004 - 10:21 PM)
Where did you get those numbers? Stock 3s's are about 8-9psi. Depending on the ecu they range from 200 to 225. 12psi is around 250 at the crank of a JDM 3s and 225 with US spec.
This post has been edited by Supersprynt: Apr 17, 2004 - 9:54 PM
post Apr 17, 2004 - 10:31 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
so far my 5sfte is very reliable. 600 miles now.
power wise its good to. untuned and stuff it feels so quick. once i get money to get it dynoed and run 2.5 - 3" turbo back exhaust system with high flow cat. it should see significant gains. im running 8psi (stock 3sgte wastgate)
post Apr 18, 2004 - 7:21 AM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE (Supersprynt @ Apr 17, 2004 - 7:52 PM)
I thought the 3s's were stock at 12psi.
You know alot more about them than I so I stand down on that remark. Fuel cut at 12? I sware 12psi has something to do with the 3sgte.
post Apr 18, 2004 - 8:43 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
First of all, i think every oe is forgetting why the 3s is so much better. The one an only point you need, is that the fact the 3s was made for boost. Its going to handle it. Turboing a engine thats not made for it, sorry guys , but its just stupid really, unless your going to replace your internals.
post Apr 18, 2004 - 9:15 AM
ghostdog
From ny to philly
QUOTE (Digndoug @ Apr 18, 2004 - 8:43 AM)
I wouldn't say its stupid. really depends how much power you want out of it. but generally yes, all things considered a factory turbo engine is a smarter choice.
post Apr 19, 2004 - 5:43 PM
droptopGT
Joined Apr 12, '04
From Nj Team 6gc
thanks for all the input.. its still quite a hard decision due to all the different responses ive gotten but i will come to my conclusion soon and will get back to yall when i do biggrin.gif biggrin.gif
Team 6gc 2oo5
post Apr 19, 2004 - 6:04 PM
Sirius
Joined Apr 15, '04
From United Kingdom
The stock 3rd Generation 3S-GTE as fitted to the ST205 produces 255 BHP, but the chargecooler helps with that so would be needed to replicate the figures.
Personally I would go with the 3S-GTE its reliable as standard and there are many many high power units out there.
post Apr 19, 2004 - 6:09 PM
shid
Joined Jan 8, '04
From LA
I think I'm going to go 5S-FTE for a couple reasons
I don't have the money to spend on a swap
I don't have the time to donate my car to a shop, even for only 3 weeks or so
I have a vert, which is already chopped in half. It probably can't hande that much power
I don't need that much power
post Apr 19, 2004 - 6:10 PM
celicarocker
Joined Sep 25, '03
From cranston RI
you also have to coicider that a custom turbo is alot cheaper than a 3s swap, not to mention alot easier....
post Apr 19, 2004 - 6:21 PM
LatinKraze
Joined Oct 22, '03
I heard that the monetary figures average about the same, 5sfte and 3sgte, by the time the set up is complete.
post Apr 19, 2004 - 7:51 PM
shid
Joined Jan 8, '04
From LA
Moneywise they're no where near the same.
Lo-Fi Version Time is now: November 27th, 2024 - 4:07 PM
