switches, pics |
switches, pics |
May 5, 2004 - 5:36 PM |
Enthusiast Joined Oct 31, '02 From Boise, ID Currently Offline Reputation: 2 (100%) |
Every switch job is so different, there is no one way to do it. If you need help, let me know. If you want to do them really simply, my switches, or Drocay's are the simplest. If you need something more than that, or have some different ideas, go for it. If you want help to make them like mine, pm or email me, and I can help you out. -------------------- psalm 69 |
May 5, 2004 - 7:48 PM |
Enthusiast Joined Nov 29, '03 From Hampton, VA Currently Offline Reputation: 0 (0%) |
You could always hotwire them like I did
May 5, 2004 - 8:41 PM |
Enthusiast Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
where do you hook up for the power? i hooked it up to the cig. lighter but it kept on blowing fuses.
May 5, 2004 - 9:46 PM |
If you want to do it the "right" way, buy a battery, either a basic one or a cool looking one, and wire it up to that. I need to do that myself. What I did is quite simple. I just pulled out my toyota manual and looked up the info on the fuse box. I found a fuse that had at least 12 volts and wasn't being used and wedged my lead into the slot with the fuse. For my gauges I did the same thing but with my fog light's fuse. Again this probably isn't the best way, but it'll get ya by. If you can though, go with a battery.
May 22, 2004 - 12:05 AM |
Enthusiast Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
I just got 4 from Kmart and hooked them up. 1 for my sub, 2 for neons and 1 for future use, perhaps fog lights..
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
May 22, 2004 - 8:24 AM |
here a pic of my fog light switch i installed
13.6@108MPH, 5SFTE Powered |
May 25, 2004 - 12:44 AM |
Enthusiast Joined Jul 22, '03 From Raceland, LA Currently Offline Reputation: 0 (0%) |
i've got a 4 switch setup under my deck - check it out Here
May 25, 2004 - 1:57 PM |
Enthusiast Joined Nov 27, '03 From Ireland Currently Offline Reputation: 0 (0%) |
there is a pretty cool range of switches available form savage, they are a brushed silver finish with the words etched on to them (start, neon, nos,boost,etc..) they glow up blue and will fit directlly into the indentation on your driverside air vent.
I think you can get them at www.demon-tweeks.co.uk |
Lo-Fi Version | Time is now: November 30th, 2024 - 2:36 PM |
