![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 23, '03 From New Orleans Currently Offline Reputation: 5 (100%) ![]() |
Okay other than the norms, ie..turbo, bov, map sensor, etc...
What is needed to keep it as safe as possible?? I'm planning on getting the MSD BTM 6b, i believe, Greddy Profec E-01 Electronic Boost Controller, & misc gauges (boost, oil pressure, EGT). I just want to know what else would be good to do?? Any comments welcome. & I want to just run 8 psi till i get a head job and get forged pistons. But how should i contend w/ my friends.lol I think i should own david's integra vtec, seans 300ZX NA, and definitley Jeremy's OZ lancer. But how will i do against a mildly tuned 95 Mustang 5.0 GT & jamie's 67 falcon, w/ 351, i know he'll burn me lol. Thanks for words of advice. & i'm not getting a 3sgte, sorry, I may do a head swap though. |
Personally i think 8psi on a N/A motor is decently high. Your going to want to get lower compression pistons. I'm thinking u will be safer with 5 - 6psi.
![]() Enthusiast ![]() ![]() Joined Mar 21, '04 From united kingdom Currently Offline Reputation: 0 (0%) ![]() |
a boost controller cant decrese boost below that regulated by the wastegate. it would only be used to increase boost really. you still get boost spikes with a boost controller at stock boost -------------------- GT4 ST205 79 modifications and rising!!
spec list: http://sox-japoc.co.uk/forum/garage.php?mo..._vehicle&CID=10 |
A boost controller can go low or high. I had my 3s @ 5lbs yesterday.
This post has been edited by Supersprynt: Apr 20, 2004 - 9:07 AM -------------------- |
Enthusiast ![]() ![]() Joined Jan 16, '03 From Wichita KS Currently Offline Reputation: 0 (0%) ![]() |
does it cause any problems going lower than stock
Enthusiast ![]() Joined Apr 15, '04 From United Kingdom Currently Offline Reputation: 0 (0%) ![]() |
A boost controller can not be used to run less boost than your actuator is set to.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 15, '02 From Corona & Vallejo, CA Currently Offline Reputation: 0 (0%) ![]() |
My boost controller will not go below stock boost (8 psi).
i'm wondering if the rods and pistons from a 3sgte would work or not?? I know their different blocks but i am just curious.
Thanks i'll look into getting pistons. but would it be better to build the head? or block? I plan on doing both, i'm thinking of just doing a whole build. |
Lo-Fi Version | Time is now: April 24th, 2025 - 6:07 AM |
