> TMIC vs. FMIC, Which is better?
post Apr 21, 2004 - 10:22 AM
Yota
Joined Feb 27, '04
From Illinois
I'm getting ready to purchase an ST205 for my ST. But I don't know whether I want to keep the TMIC or convert to a FMIC. The TMIC would keep it more of a sleeper, but I'd want the vented style CF hood to go with. But I kinda want to have a FMIC as well. I'm thinking that which ever way I go, I'll be spending close to the same amount of money in getting a FMIC or a Vented Style CF Hood. Which would you guys recommend?
Thanks guys!
post Apr 21, 2004 - 10:36 AM
well the st205 is water and air cooled so it does a MUCH better job than the st185....less heatsoak..so you can use the 205 inercooler, and it will do a good job,..its more a matter of what you want at that point IMO
post Apr 21, 2004 - 10:41 AM
Yota
Joined Feb 27, '04
From Illinois
Does anyone know where I can find a vented style CF Hood that only weighs 10-20 lbs? My buddy bought a VIS one and it is fiberglass with a Carbon Fiber overlay. It weighs 50 lbs. I don't want anything like that!!!
post Apr 21, 2004 - 12:21 PM
Sirius
Joined Apr 15, '04
From United Kingdom
Difficult choice - depends on many things.
What are your goals in terms of power? The ST205 chargecooler is good for 400 BHP.
But it is fairly complicated with pump and radiator etc.
If you wanted the nice look of a big front mount - I guess you could get a huge radiator for the chargecooler fluid - it would look exactly the same.
post Apr 21, 2004 - 12:51 PM
If u got a vented hood idk if the TMIC would fit correctly.
post Apr 21, 2004 - 3:50 PM
Junior
Joined May 5, '03
From Toronto
I though the vented hood is needed to use the TMIC. Has anyone used a TMIC with a stock USDM hood?
post Apr 21, 2004 - 3:55 PM
LatinKraze
Joined Oct 22, '03
QUOTE (Junior @ Apr 21, 2004 - 1:50 PM)
Hot air rises. so if you got TMIC with stock hood, you aint cooling jack.
post Apr 21, 2004 - 4:13 PM
5sfeTurbo
Joined Apr 14, '03
QUOTE (LatinKraze @ Apr 21, 2004 - 1:55 PM)
Preach on brother!!
post Apr 21, 2004 - 4:45 PM
It'll fit under the stock hood, however, like latin said, u'll get heat soaked.
I put a hood scoop on mine to allow air in when driving and out while sitting. And wow can you see the heat rising outta the scoop.
post Apr 21, 2004 - 9:53 PM
Yota
Joined Feb 27, '04
From Illinois
Where would the problem be on the Vented hood?
post Apr 21, 2004 - 9:59 PM
UT_Celica_GT
Joined Dec 9, '03
From Utah
anyone know pricing on vented hoods. how much to buy a GT4 hood, would it fit right onto a 6gc? How much would it cost to get custom FMIC instead? what are the pricing differences? Particuarly those that have swaped w/o a clip what did you do?
post Apr 22, 2004 - 7:17 AM
Unless im wrong, the vented hood steeps down further? I would have to see a pic. But with the air to air, you want air going in...thats why i did mine like an alltrac scoop. Ram air.
post Apr 22, 2004 - 7:23 AM
neoklis
Joined Oct 24, '03
From Cyprus
QUOTE (LatinKraze @ Apr 21, 2004 - 8:55 PM)
I have a gt4 so here it goes once and for all. The hood thing is merely cosmetic on the GT 4 as the hood has the heat shield material underneath as all cars. So i cant really see how you cant use the oem hood. Yes it gets hotter under the GT4 hood but that's about it. As its water-to-air heat and clean air is not that important as witha FMIC.
post Apr 23, 2004 - 6:41 PM
LatinKraze
Joined Oct 22, '03
Hmmmm, i guess turbo tone must have removed his heat shield material. His vent seems to be functional. I was basing my reply by what i saw in his profile. I guess im wrong.
post Apr 29, 2004 - 5:14 AM
tufy
Joined Dec 3, '03
From Cyprus
i have fmic on my car.. i put fmic becauce my ic radiator was broken in an accident. if you have money to spend some where. spend it down pipe, on boost controller ecu remappin ect.. stock intercoller is very effective on our cars. is your country very hot? if you ll chose one for sure buy an fmic.. more effective then tmic and seems nice.
post Apr 29, 2004 - 11:07 AM
uzthedentist
Joined Mar 21, '04
From united kingdom
rubbish, you can easily remove the underbonnet lining and fibreglass shielding and still retain the timing belt snorkel. Thenm the vent is functional
directly above the manifold
GT4 ST205 79 modifications and rising!!
spec list: http://sox-japoc.co.uk/forum/garage.php?mo..._vehicle&CID=10
post Apr 29, 2004 - 12:38 PM
kuya1284
Joined Nov 15, '02
From Corona & Vallejo, CA
QUOTE (uzthedentist @ Apr 29, 2004 - 9:07 AM)
I concur!
This post has been edited by kuya1284: Apr 29, 2004 - 12:39 PM
post Apr 29, 2004 - 3:46 PM
UT_Celica_GT
Joined Dec 9, '03
From Utah
Good! I read that and was all depressed cuz I was excited to get the hood for cosmetic and cooling for the TMIC. Glad to hear that it's not a big deal to open that vent up.
post Apr 29, 2004 - 3:51 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
Thats just Sexy.
Team 6gc 2005
uzthedentist
Joined Mar 21, '04
From united kingdom
just remember to retain the 3 studs for the timing belt snorkel
Lo-Fi Version Time is now: November 27th, 2024 - 4:07 PM
