> Mr2 turbo vs. celica gt, thinking of getting one...
post Apr 21, 2004 - 12:25 PM
ScoobyDooCruiser
Joined Oct 31, '02
From Boise, ID
I'm thinking of selling my celica and getting an mr2 instead. I want to build myself a car I can run some rallies in, and the US celis are just too slow and heavy to make a good car. I am starting to get enough $$$ to actually upgrade the suspension and engine on a car, but I figured it would probably make sense to get a car that is a faster base.
I no longer need the back seat and larger inside of my celica, I drive a 1989 volvo 240 as my commuter and people hauler, so I now want something I can use on the weekend for a fun drive, and can work on, and maybe get involved in a little racing.
Here are some of the advantages (I think) to both cars... if you can think of any others (especially if you own an mr2) add them...
Celica-
Back Seat + real trunk
Safer in an accident
cheaper to maintain
better gas mileage (right?)
Sexier looking (My opinion)
Mr2Tubro-
Bigger engine
Mid engine so better balance (i think...)
Lighter weight
Whats the opinions on the advantages and disadvantages of each? Let me know!
psalm 69
post Apr 21, 2004 - 12:28 PM
Its heavier
Engine is smaller than the GT
MR2 has real trunk also.
MR2 would cost more to maintain to do the fact that the engine is not very easy to access.
This post has been edited by Supersprynt: Apr 21, 2004 - 12:29 PM
post Apr 21, 2004 - 2:45 PM
uzthedentist
Joined Mar 21, '04
From united kingdom
u gonna run an mr2 in a rally????????? that thing oversteers so much on tarmac god knows wat it will do on gravel. Ull spin so much ull end up losing so much time its not even worth entering!
GT4 ST205 79 modifications and rising!!
spec list: http://sox-japoc.co.uk/forum/garage.php?mo..._vehicle&CID=10
post Apr 21, 2004 - 2:55 PM
boosted_K2
Joined Aug 30, '02
From Michigan
MR2s and rallys dont mix
MR2s are good for road track racing, hill climbs, autocrossing, and dragging.
Celica GT is lighter and has a larger, yet less capable motor. and yes, the MR2 is nearly 50/50 weight balanced.
if you are not going to do 99.9% of the work on the car yourself, its better to stick with the celica because you will get extremely frustrated finding a decent shop that can do decent work in a decent ammount of time on the MR2, even most dealerships get baffled at the MR2 turbo.
No but I don't buy it
Cause I'm...
post Apr 21, 2004 - 3:34 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
I've rally crossed our MR2 (91 n/a)... and I tell ya... it's pretty interesting. It's true that MR2s and Rally don't mix... the rear-end just can't make up its mind whether it wants to grip, or slide... so there's a challenge to it. At high speeds... don't expect the sucker to go in the direction you want it to for long.
post Apr 21, 2004 - 5:42 PM
ScoobyDooCruiser
Joined Oct 31, '02
From Boise, ID
Whats the best cheapest car then to start with? My overall budject is going to be bout $6k-$8k but that has to include mods. What would be the best car to go with? If I go for 2wd I'm in an easier class, but does the celica have potential? Woul'd the 3sgte be worth it for rallies, or should I put it into suspension and other things? Let me know...
psalm 69
post Apr 21, 2004 - 5:48 PM
an NA mr2 has the same 5sfe as the clica. the tubo version has a 3sgte. so, i dont know why you guys are saying it has a smaller engine.
if i were you id buy myself a 90+ eagle talon TSI. its awd, tubo and very ****ing fast. you can buy one for next to nothing.
the other option would be to buy a 5th gen all trac.
post Apr 21, 2004 - 6:09 PM
ScoobyDooCruiser
Joined Oct 31, '02
From Boise, ID
QUOTE (lagos @ Apr 21, 2004 - 2:48 PM)
They're 4wd ain't they? I'm thinking of staying with 2wd to keep in the easier class.
psalm 69
post Apr 21, 2004 - 6:28 PM
TTE
Joined May 19, '03
From NJ
If you are thinking about rally st185 would be cheap alternative , 4wd and 3sgte engine
post Apr 21, 2004 - 7:06 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
2wd huh, there are very few real rally cars in the world that are 2wd.
i think the ONE is a Citroen. or an Xsara... or 206, i can't think right now
but yea, rallying in any other drivetrain would not be the same. a RWD would NOT be ideal in rallying especially modded due to the fact that too much gas in any turn would kick the back end out, unlike in AWD where the slips transfer the power till it grips.
an FF would work, but it would be tricky.
i can't comment on mods to do to an FF though, because it's all on the driver and preference(at least i think so)
post Apr 21, 2004 - 7:08 PM
LatinKraze
Joined Oct 22, '03
3TST
Joined Sep 27, '02
From UK
I have also heard that MR2's don't handle that well.
However, aftermarket parts for the MR2 seem more readily available than that for the Celica (certainly that's the case in the UK).
Go for a Celica GT with 3S-GTE motor.
post Apr 21, 2004 - 9:19 PM
QUOTE (3TST @ Apr 21, 2004 - 5:08 PM)
mr2s handle very well but are very hard to drive. you have to really be carefull with them becuase the slight mistake in a turn could cause you to spin the car out. they are not as forgiving as a fwd car.
post Apr 21, 2004 - 11:48 PM
boosted_K2
Joined Aug 30, '02
From Michigan
wow this thread has horrible info.
he was talking mr2 turbo vs celica GT... 2.0L vs 2.2L, the 2.0L 3sgte is SMALLER.
MR is NOT by any means a setup that is good for rallying.
there are LOTS of 2wd, front or rear rally vehicles. they just dont compete in WRC. the WRC cars are all equipped with 4wd and motor size are all 199_ CCs. wether thats the equipment they are given stock or not, thats what they have on them when they hit the FIA World Rally Championship.
a decent condition MR2 turbo is going to run you 6-8k before mods. a decent condion ST185 is going to run you 5k+ and finding one is no picnic. id say your just better off first finding what class specifically youd like to run in as an entry level participant, and what is needed to enter it. try to find something you can run your celica in, since you already have it.
Cause I'm...
post Apr 22, 2004 - 12:38 AM
kustomplay
Joined Apr 22, '04
From Buffalo NY
hello all
I drive an MR2 MKII N/A
the turbos are nice but the N/A's will last a lot longer and have almost the same HP as the turbos if you swap it out with a 3sge or a BEAMS
theres also a 1MK engine thats a 6 with 220hp that bolts right into our cars
if you have any questions about the MR2 drop me an IM at Kustomplay (AIM)
the do ski out because of the lack of weight but once you get the feeling of the car you will correct it without thinking it will become 2nd nature
half the fun of having an MR2 is trying to drift it and recover it smile.gif
post Apr 22, 2004 - 12:50 AM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
QUOTE (kustomplay @ Apr 21, 2004 - 10:38 PM)
hello all
I disagree, a well kept 3sgte will last as long as a 5sfe, my car has 180k miles and still runs amazing, Ive read of people with turbos well over 200K and running good. The only difference is with a turbo you have a little more to replace as the car ages.
How do you drift your N/A??? I have a hard time even spinning my tires with out getting grip in my turbo, then again Ive only tried once and I dont like beating the car up.
post Apr 22, 2004 - 2:32 PM
Consynx
Joined Dec 25, '02
maybe he meant gravel roads
post Apr 22, 2004 - 2:34 PM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
QUOTE (Consynx @ Apr 22, 2004 - 12:32 PM)
Well that would be a power slide not a drift, and I couldn't imagine doing that to an mr2 or any nice car for that matter confused.gif
post Apr 24, 2004 - 9:36 AM
uzthedentist
Joined Mar 21, '04
From united kingdom
the sw20 mr2 is a terrible handling car, take it on a rally and ull severely regret it
post Apr 24, 2004 - 2:00 PM
boosted_K2
Joined Aug 30, '02
From Michigan
QUOTE (uzthedentist @ Apr 24, 2004 - 9:36 AM)
bull****, MR is the best setup possable for road racing. it just takes the most track time and practice to learn it. but if you are speaking strictly for rally, yea MR is HORRIBLE.
Cause I'm...
Lo-Fi Version Time is now: February 24th, 2025 - 4:07 AM
