> Dropped boost guage, Help
post Apr 21, 2004 - 2:47 PM
JWalk1818
Joined Aug 30, '02
From North Carolina
Well i dropped my boost gauag and i took it apat to fix it well i set it to 0 and tightened the bolt down and it goes about where my vaccum was which is about 21 o so well then when i tuned the ca off it didnt go all the way to zero. well i took it back apart set the pieace above zero and then my vaccum only went to like 18-19 but when i cut the car off it went to zero but if i tap it it goes above zero which of these is the correct reading?
99 Toyota Tacoma
post Apr 21, 2004 - 3:08 PM
boosted_K2
Joined Aug 30, '02
From Michigan
if nothing is actually broken inside of it, you have to have it hooked up and turn the car on so it gets a reading, THEN calibrate it to zero.
No but I don't buy it
Cause I'm...
post Apr 21, 2004 - 3:21 PM
JWalk1818
Joined Aug 30, '02
From North Carolina
ok can you explain actually how to do that to the detail i would getaly appreciate
99 Toyota Tacoma
post Apr 21, 2004 - 4:03 PM
SpedToe169
From Dallas, Tx
If you've dropped it and bent the tube then its junked. You can make it work, but it will never be as accurate again. I did the same thing with mine.....yet another good reason to just get electric gages to begin with.
Lo-Fi Version Time is now: November 30th, 2024 - 6:35 PM
