> Upgrading the suspension w/out lowering?, looking for high quality parts
post Apr 21, 2004 - 5:51 PM
ScoobyDooCruiser
Joined Oct 31, '02
From Boise, ID
I'm looking to improve the the handling on my celi, but not drop more than an inch if necessary. I'm thinking of getting into rallycross, and I need to keep the car off the ground for clearance.
What is the best thing to do to increase handaling, without lowering too much (if at all)?
I'll need a sway bar, what is a good brand?
Also, are kyb shocks going to be the best?
Should I do anything with spring?
Any other ideas would be great.
If you have product names or webpages you could link to, that would be great (i'm new to the whole suspension thing)
Thanks.
psalm 69
post Apr 21, 2004 - 6:21 PM
3TST
Joined Sep 27, '02
From UK
I think that there is only one manufacturer available.
F&R Suspension Techniques Sway Bars - currently deals on ebay.
Also get F&R strut bars.
Someone on the site made some which look and work great.
KYB are good, but you'd probably want to go for Koni Yellows.
Yes, I would say you need a stiffer spring.
Go for a set of Eibach springs offering a 1" drop.
All this will sort out your suspension and handling.
post Apr 21, 2004 - 9:26 PM
jgreening
Joined Jan 17, '04
From Illinois
great advice 3tst
post Apr 21, 2004 - 9:33 PM
Pali_playa
Joined Apr 4, '04
From VA, USA
how much will all that cost? is that pretty much a compete suspension sys?
post Apr 21, 2004 - 9:54 PM
FallenHero
Joined Dec 26, '02
From Alabama
Springs $200
Sway bars $250
Koni's $500
Strut bar $150
post Apr 22, 2004 - 8:48 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
I would almost say you would be fine with sportlines an kyb's... my buddy dose rally x an he said my car would be perfect, he said it handled better then half the cars there, well a hand full that he drove... then just get some sway bars.. struts bars wont do too too much, but it ccould help a lil... nopi, I think has upgraded sway bars with links front an back, for around 250...
post Apr 22, 2004 - 12:37 PM
TTE
Joined May 19, '03
From NJ
The best solution above all the parts its thicker rear sway bar. Makes realy big difference
post Apr 23, 2004 - 7:07 AM
3TST
Joined Sep 27, '02
From UK
The celi comes with sway bars as standard...ok they are thin but I would leave changing them until last.
Uprate the shocks and springs (lower by 1" or 1.5"). This lowers the center of gravity and improves handling.
To get rid of the roll, I would go for a set of front and rear strut bars.
They made an enormous difference.
Thereafter, you will probably find that you only need to upgrade the sway bar bushes to urethane ones.
This is what I have found.
Oh yes, make sure you get a decent set of tires.
post Apr 26, 2004 - 8:42 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
I would say upgrade the sway bars before adding strut tower bars, in my buddies three cars, two of wich hes upgraded completely, iv noticed alot more dif in the sway bars compared to the strut tower bar, whcih there really is minimal change.
post Apr 27, 2004 - 5:43 AM
Sirius
Joined Apr 15, '04
From United Kingdom
A company called whiteline also make sway bars - they dont list applications for the ST202 but much of the stuff does fit you might want to investigate that smile.gif
Lo-Fi Version Time is now: April 24th, 2025 - 6:12 AM
