3sgte swap trouble help!!!, need someone to answer me few questions |
Apr 21, 2004 - 8:23 PM |
Enthusiast Joined Jun 21, '03 From Pennsylvania Currently Offline Reputation: 3 (100%) |
i dont know where the two blue wires go from the resistor pack? (blue with black strip to??? and blue with white stipe go to???) i am stuck ....
and i think my car will run after that? please help!!!! thanks, dg -------------------- |
Apr 22, 2004 - 2:45 PM |
hummmm i might have figured out that problem ,,,,,,,not sure though.
what could be wrong if my car turns over but does not start up? no fuel or no spark would be my guess ....... how could i check to see what is happening thanks, dg -------------------- |
Apr 23, 2004 - 10:15 AM |
Enthusiast Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) |
well to check for fuel.. you can pressure test the fuel line to make sure your getting pressure, you will also want to check to make sure the fuel injectors are pulsing, easiest way to do this is to touch the injectors and have someone turn the key to the car on/engine off postion. you shoud feel a vibration directly in the injector. another thing you might want to do is go and purchase a NOID light from autozone or some place like that. you will need to unplug the wire connecter on the injectors and plug in the noid light to that then try and turn over the car.. the noid light will flash on and off and that will tell you if your injectors are fireing or not. to check for spark easiest way is to 1st undo the distributor cap and they and turn over the car.. check to make sure that the needle is moving at about 1 rmp per second or so.. every car is a little differnt but that is a decent base to go by. also make sure that its not too corroded or nething. if everything looks fine then hook the distributor cap back on and take out your sparkplugs one at a time, once you get the plug out connect it back to the wire and touch the end of it to something metal under the hood.. valve cover or exhaust manifold works good for this, then have someone turn over the car.. if you see a spark then the plug is firing.. check condition of the plug if its nasty repalce it. repeat this for all 4 plugs. If all this checks out then its either a air problem or a sensor is bad or your just missing something. I would check to make sure that the O2 sens is good. also might wanna check the cataliytic to make sure its not gummed up.. it prolly wont be cus the cat is HUGE on the 3sgte but theres always a possiblity... easiest way to check if the exhaust system is plugged up is to have some one turn the car over while you put your hand over the exhaust tip... if you can feel the exhaust pushing you hand then its prolly fine. hope that helps man... also check the fuses... prolly not the prob but you never know -------------------- 99 project version 3.0.. hello SEMA 2010 =) |
Apr 23, 2004 - 11:29 AM |
Enthusiast Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
Talked to DG lastnight and I think hes got the fuel problem worked out but it still doesn't fire.
-------------------- Member of Team 5sfTe
Apr 23, 2004 - 11:55 AM |
Enthusiast Joined Apr 15, '03 From San Jose, CA, USA Currently Offline Reputation: 1 (100%) |
check the ignition system. check that the ignitor is plugged all the way in, same for the coil, and that all connections are made.
Also, it may not have set off a check engine light yet (or if your check engine light even works) you could check that. |
Apr 24, 2004 - 12:04 AM |
well i got most of things worked out except for the spark plugs . They just will not spark????? i have it narrowed down to where i know that the coil is getting about 2-3 volts of power from the two wires that plug into it. After that..... i get no kind of spark signal at the cap and rotor at all. how can i check the coil itself to see if it is good or bad?
thanks for all your help guys!!!!! appreciate it alot, DG -------------------- |
Apr 24, 2004 - 1:07 PM |
alright!!!! i figured out my problem. i had a little help from a guy from another country but it is all good now. i had a low voltage reading and was not sure if it was supposed to be that way or not. i have been trying to get ahold of mike for like 2 weeks to ask him about it. he must be busy or something.... so i just started testing my own ideas of what i think could be bad and when the guy that i emailed said that "the reading should be 12 v and not 2.5" i got a idea and put it to the test and it all worked out.
i am excited to hear the engine run for the first time. i now have a clutch problem that i am unsure of? for some reason i am not getting full grip and i will have to find out why. i will keep you guys posted as i finish up my car really soon i guess doing all my own work and saving my money was a good idea! and get this guys...... it only took me a month to finish the swap. DG -------------------- |
Apr 24, 2004 - 1:19 PM |
Enthusiast Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
nice man, cant wait to see it finished.
-------------------- All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Apr 26, 2004 - 7:55 PM |
Moderator Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
sweet dg I cant wait to see it ... you better be comming to the next meet so I cant ask you a million ?'s about ur swap.
good job I like a do it urself project later defgeph -------------------- I will return one day. |
Apr 26, 2004 - 8:20 PM |
First test run went good !!!!
cant go to hard on it yet cause of the new clutch but i can just feel the power wanting to come out and the engine just wants to go........ there is no body panels back on the car yet so as soon as i get the car back to street legal condition i will post an update DG -------------------- |
Apr 27, 2004 - 7:30 AM |
Who else has 3s in the tri-state area. I know PA isnt exactly tri-state but its close... i was just curious.
Apr 27, 2004 - 12:39 PM |
I'll will be doing the 3s swap soon .... I just picked up my beater car so I'll be parking the celi for good now.
sprynt.... If you dont mind I would like to roll to ur house to check out ur car one day. I just want to see to swap in person before I do it. later defgeph -------------------- I will return one day. |
Apr 27, 2004 - 2:37 PM |
Fine with me but it'll be painted in the month of may.
Oh and DG, what kinda offset do you have on ur wheels? This post has been edited by Supersprynt: Apr 27, 2004 - 2:39 PM -------------------- |
Apr 27, 2004 - 6:33 PM |
Enthusiast Joined Sep 26, '03 From Pittsburgh Currently Offline Reputation: 0 (0%) |
I am ordering a 3sgte in about a month so by summer i will have my swap done.
Apr 27, 2004 - 8:04 PM |
I have no idea what the ofset is on my wheels?
Stargirl, who are you getting to do your swap? DG -------------------- |
Apr 27, 2004 - 9:15 PM |
My boyfriend will be doing the swap. Did you do yours yourself? Are you coming to carlisle do you know yet?
Apr 28, 2004 - 12:50 AM |
Enthusiast Joined Apr 14, '03 From Long Island, N.Y. Currently Offline Reputation: 1 (100%) |
Whats the best way to get the 3sgte. i was looking at a rebuilt one for about 2500. www.atk-engines.com. good luck dg. you still doing those strut braces?
Apr 28, 2004 - 7:37 AM |
clip form.
Apr 28, 2004 - 10:53 PM |
When is the carlisle? i think it costs too much this year for me to enter?
Yes, i did my own swap from start to finish. All by my self!!!!!!!!!!! took me about a month total. if you got any questions about it just email me. There is a site for clips i notice that sells front cuts www.flashoptions.com check it out???? DG -------------------- |
May 2, 2004 - 9:26 PM |
Update:
Well almost all bugs have been worked out ...... the car has all panels back on and i have driven the celi for the last 2 days. my speedo and odometer is not working for some reason ? i think i will have that prob worked out soon but i just want to break in the clutch so i am guessing my speed at the moment. feels good so far but i notice a hesitation around 5000 rpm like the turbo is cutting out or something???? not sure if it is a prob yet cause i dont want to stomp it to the floor quite yet. cant really just go out and stomp it down and see if it does it all the time till my clutch is broke in a little more. if anyone has an idea of something that may be, just feel free to let me know! hummmm, what else...... uuhhh i have to recut the front end to get it to fit with the big front mount. i am just runnin the old front end for now. i noticed a big difference in the handling with the side tower bars i put on. and i am not just saying that either. bad thing with em is that now i feel more little road bumps cause they really make the car too stiff in my opinion..... but oh well. i guess since my tires are about the thickness of rubber bands that it does not help the situation. oh yeah.....and i am just running my 2.25 exhaust till i finish my full 3" setup. i think that is all DG -------------------- |
Lo-Fi Version | Time is now: November 27th, 2024 - 8:06 PM |
