*Update*, Climate Control |
Apr 22, 2004 - 9:52 PM |
Enthusiast Joined Jun 23, '03 From Hialeah, Florida Currently Offline Reputation: 0 (0%) |
they sell bulb covers at auto zone that u can use, i work there
Apr 22, 2004 - 10:20 PM |
Enthusiast Joined Jan 12, '04 From hawaii Currently Offline Reputation: 0 (0%) |
awesome! is that a kenwood xcelon deck too?
Apr 23, 2004 - 1:45 AM |
I attempted to do this to mine today, and failed miserably.
First off, I forgot to paint the area where you can control fan speed. Also, I painted the light reflectors for the buttons too much, so they're dim to the point where I can hardly see them. Also, in one of the buttons, you can get a hint of green. And worst of all, none of my lower button lights work anymore. The fresh/recycled air button, the A/C button, and the rear window defroster buttons no longer light up, although their small square indicator lights light up. Also, part of the warmth adjustment area is dim, and the area that surrounds the fan speed knob is very, very dim. Unless anyone has any ideas, I'm going to scrap this one and just find a used climate control unit, and keep it stock. Here's a photo of what happens when a retarded kid tries to mess with his climate control unit.
Apr 23, 2004 - 6:26 AM |
Enthusiast Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
i also tried, but just the knobs and they turned out horrible. There so dim that now the large one i can barely see and the small one is just dead.
-------------------- All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Apr 23, 2004 - 1:15 PM |
Enthusiast Joined Feb 23, '03 From Florida Currently Offline Reputation: 0 (0%) |
Hmm.. are all the lights working? did u take off the green caps?
I replaced all the LEDs in mine... so I never tried this... but you might wanna look into that.... |
Apr 23, 2004 - 2:11 PM |
My lights probably aren't working on the bottom of the box, but they did before. I did take off the green caps. -------------------- New Toyota project coming soon...
Apr 23, 2004 - 2:16 PM |
Moderator Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
coomer what type of paint did you use ?
If you want you can just scrape off the paint with some paint thinner and try again. *Oh you need to get new bulbs ! Go to toyota get new bulbs they are like 6 dollars each put them in and you should be fine. And you might wanna touch up off on the control. dont lose hope get the bulbs trust me -------------------- I will return one day. |
Apr 23, 2004 - 3:31 PM |
Enthusiast Joined Apr 16, '04 From Worcestershire, UK Currently Offline Reputation: 0 (0%) |
Has anyone considered using a blue acetate? I might try placing a blue tint film inside the buttons and see what happens. There is also a great article about how some bloke used a blue neon tube inside his a\c unit in his 7th gen celica at everythingcelica.com (you'll need to register to view the whole article).
Apr 23, 2004 - 3:39 PM |
Enthusiast Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
soo.... we can take them off to get an all white climat control (minus the blue/red on the temp)??
Apr 23, 2004 - 5:21 PM |
I'd think that you'd be left with off-white/greenish light if all you did was remove the covers. Also, Defgeph, I used the Testors transparent candy apple red paint. I'll try getting new bulbs from Toyota on Monday and see if that solves my problem. How many bulbs did you buy? -------------------- New Toyota project coming soon...
Apr 23, 2004 - 5:47 PM |
I bought 3 so I had extras I used two.... It all came together when I changed the bulbs
Edit : when you go to toyota and he asks you what lights are you talking about .....tell him the twist in ac lights. Cause at first hes gonna see the defroster light ..... it will only list one ac bulb ...order three of those bulbs wait I still have the part number I'll be back with it defgeph This post has been edited by defgeph: Apr 23, 2004 - 5:55 PM -------------------- I will return one day. |
Apr 23, 2004 - 6:01 PM |
ok here it is
part number : 84999-70007 all you have to do is take off the condom and twist em in And if you want Da Heater Box Thingy to be white then just take off the caps ... they just wont be hyper white defgeph -------------------- I will return one day. |
Apr 23, 2004 - 8:52 PM |
here is a pic of one button.....
back front first cable to pop (blue)....... by the gas pedal second cable (black)....... in the engine bay on the fire wall unhook both unscrew the box (2 screws I think) unplug the 3 connectors behind the unit and pull it out....... as you pull it out look at the black cable follow it to the white tube. the tube is a guide back out to the engine bay the pic is below it in the dash to the left right under the blue cable you'll see the opening when you put the unit back make sure you put the black cable in that tube hope that helps you guys defgeph -------------------- I will return one day. |
Apr 27, 2004 - 1:47 PM |
Enthusiast Joined Feb 20, '04 From Washington Currently Offline Reputation: 0 (0%) |
Hey, Having trouble with the britness of the Climate Control??? Well, do I have a solution for you! Cut the GREEN wire in the back of the unit!! This is the sending wire that tells the unit to dim the light bulbs. HA! I'm going to try it in a few hours I'll keep you all posted!!!
Apr 27, 2004 - 2:16 PM |
Then wouldnt that hinder the effect of the lights dimming when you turn ur lighs on ?
My lights are bright enough They look stock. defgeph -------------------- I will return one day. |
Apr 27, 2004 - 2:48 PM |
Mine are really dim, so this would help, but I think I'm better off taking off the paint, spraying just one coat on the light reflector things, and then putting it back in. Also, I have a tiny bit of green showing through at the top of those indicator lights...do you get that defgeph? -------------------- New Toyota project coming soon...
Apr 27, 2004 - 2:54 PM |
No, I dont have any green or clear showing. I painted the little LED reflectors too. Not the LEDs. Look at my picture above you can see the inside of my buttons. defgeph -------------------- I will return one day. |
Apr 27, 2004 - 11:04 PM |
A bit long but worth it:
Okay so I disconnected the GREEN wire (not the one with a white stripe but the GREEN one!), and then the bulbs didn't light up at all, even after I re-connected it!! Wierd huh!! HOWEVER!!! I figured it out, connect the spliced green wire from climate control unit to a GROUND!! HA! and the lights never dim, they are fairly brighter!! Also, try (if you haven't) turning your dim switch all the way on. If you do this mod, you will have to turn it all the way off though! Connecting the green wire to a ground reverses your dim unit!! also strange, but it doesn't matter!! Doing this will save you about $60 for a new unit! Hope this helps!! TIP: DON'T PAINT THE BULBS!! Also, the green tint is comming from the small bulb in the lower left corrner on the circut board. its right below the right bulb, if you pull out that unit you can disconnect that bulb and by increasing the watts (by the mod earlier) the unit wont need that green bulb to light up!! Hope this helps guys, this SMALL EASY mod has turned into a HUGE hassle! -------------------- |
Apr 28, 2004 - 3:57 AM |
Enthusiast Joined Nov 6, '03 From Campbellsville, Ky. Currently Offline Reputation: 0 (0%) |
Why does everyone always do this the hard way? Just disconnect the cables at the climate control box, it's pretty simple to do and alot less time comsuming. |
Apr 28, 2004 - 6:26 AM |
problem is u can't see or reach the cables on climate control at least i couldnt when i tried a while back.
Lo-Fi Version | Time is now: December 1st, 2024 - 3:48 PM |
