Car Shaking, running >70mph |
Apr 25, 2004 - 6:50 PM |
Enthusiast Joined Mar 10, '03 From oklahoma Currently Offline Reputation: 0 (0%) |
My car starts to shake if its running faster than 70mph, what might be the problem?? thx
Apr 25, 2004 - 7:02 PM |
Enthusiast Joined May 13, '03 From New Jersey Currently Offline Reputation: 0 (0%) |
how good are your tires?
Apr 25, 2004 - 7:22 PM |
Enthusiast Joined Apr 4, '04 From VA, USA Currently Offline Reputation: 0 (0%) |
need wheel alighment
Apr 25, 2004 - 8:32 PM |
Enthusiast Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) |
Before my car had it's 75k mile checkup, it was shaking at the weirdest times- it'd shake from 65-80 mph, mildly shake 80-90, shake really hard 90-100, and then be the smoothest ride ever 100+.
weird |
Apr 25, 2004 - 9:14 PM |
Enthusiast Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
did this start after you put the aftermarket wheels on? did they come with hubcentric rings?
Apr 25, 2004 - 9:41 PM |
the shaking comes after i changed to 16" wheels with new BF Goodrich tires from walmart and installed Tein S-Tech.
Is it the alignment problem? my technician told me that i dun need to do my alignment after just a 1.5"drop... so how? whats a hubcentric rings anyway?? sorry im new... |
Apr 25, 2004 - 10:16 PM |
Enthusiast Joined Jun 26, '03 From Wisconsin Currently Offline Reputation: 0 (0%) |
were your tires balanced? -------------------- i am awesome
Apr 25, 2004 - 10:21 PM |
er... i took my four new rims to Walmart and ask them to put on new tires and i went picked it up after few hours, so im not very sure did they balanced it or not...
Apr 26, 2004 - 12:51 AM |
Enthusiast Joined Jun 21, '03 From FRANKFORT,KENTUCKY Currently Offline Reputation: 0 (0%) |
Your problem is that you need a new technician!If he told it doesn't need an alignment then he should be working on cars. Go get that thing aligned. It will save you from buying new tires this time next year. That may not be why it's shaking but it needs to be done. It could be that they ain't balanced like andason said. When you're going that fast and it shakes, it almost sounds like your struts aren't dampening correctly<although I doubt thats the problem.
Apr 26, 2004 - 5:01 AM |
Enthusiast Joined Sep 12, '03 From Portland , Oregon , United States Currently Offline Reputation: -1 (33%) |
Balanced, hubcentric rings is a good possibilaty they are the lil peices on the outside and inside of the rim, Alot of times shops will skimp or put em on crappy so they will fall off, another possiblity its the Struts or even worse your axles.
DTE -------------------- I am a thief.
do not buy anything from me. |
Apr 26, 2004 - 8:09 AM |
Enthusiast Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
mine had same problem, i just got alingment and balance and now its beutiful smooth all the way up to about 90 and then u have to expect some shake nothin serious though.
-------------------- All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Apr 26, 2004 - 10:45 AM |
you dont need to, alignment. like his dude said, theres no reason for one, its his wheel balance, mine does the same thing, caue i switched mine... |
Apr 26, 2004 - 12:53 PM |
its true just balance it, if your car is preferering one direction to the other it alignment if its shaking then its balance. I just did both at same time.
Apr 26, 2004 - 12:55 PM |
aftermarket wheels need hubcentric rings. Im sure walmart balanced the tires they put on. If they didnt then they are retarded but i would say that they did balance them. Also, you probably do need a alignment after the springs. Anytime you lower your car it causes some negative camber. I would get some hubcentric rings and also go get a alignment.
Apr 26, 2004 - 4:50 PM |
wait, is it the whole car or like you feel it a lil, but its most in your steerign wheel, now i feel like an ass... mine is just the steering wheel.
Apr 26, 2004 - 8:12 PM |
ermm... actually is the steering wheel shaking.... where can i get hubcentric rings? my car would go straight if i let the steering free when running.
Apr 26, 2004 - 8:47 PM |
where can i get hub rings cheaper and which type should i get? plastic? metal ot what?
Apr 26, 2004 - 9:28 PM |
Enthusiast Joined Sep 5, '03 From Grapevine, TX Currently Offline Reputation: 0 (0%) |
Stock everything. Shakes from 68-81. HOWEVER, if I let the car heat up for a full 5 minutes before I go driving (like I usually do), then I get no shakes. The thing is, after 81.. it's smooth sailing. Granted, the pedal is literally on the floor, but it's a really really smooth ride.. I cruise at 100 a lot more than anyone ever should.
-brian |
Apr 26, 2004 - 11:06 PM |
i see the hubcentric rings on ebay... i have alloy ones on my celica but i dont know which would be better. I dont really think it matters much because all the have to do it allow the wheel to sit flush and straight on the hub.
Here is another site that sells them..they cost alot more here though http://www.justforwheels.com/index.jsp?track=WM -------------------- |
Apr 26, 2004 - 11:37 PM |
which "year" should i choose at http://www.justforwheels.com/index.jsp?track=WM ?? 86~96 or 90~96?? my car is 94 tho
Lo-Fi Version | Time is now: November 30th, 2024 - 10:06 PM |
