> Stock Stereo and Amps
post Apr 26, 2004 - 8:30 AM
hermo69
Joined Dec 7, '03
From CANADA
Hey Guys,
I have a 94 ST and I only see a 4 speaker system (2F + 2R) Does the 94 ST come with the internal amp from the factory or is it just a headunit? and if it does, where would i find it? (under seat or in dash?) I hope you guys can help.
post Apr 26, 2004 - 8:33 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
in dash.
Team 6gc 2005
post Apr 26, 2004 - 8:58 AM
hermo69
Joined Dec 7, '03
From CANADA
Thanks for the info!
If i were to use an aftermarket CD player and amp, how would i bypass the stock amp? Just use a wire harness? I wired my tercel and it didnt have a amp. Now that I have an amp from the factory.....im all confused!
post Apr 26, 2004 - 9:49 AM
There are 2 wires for every speaker. On your 2 plugs, the smaller plug has 4 wires and thats 2 speakers. On the bigger plug there are more than 4 wires, but on the end there are 4 which look the same in pairs of 2. Meaning 2 look fairly alike, and another 2 look fairly alike. You would cut these and run them to the amp. A 4 channel is required and even then you'll have to double up on the wiring.
post Apr 26, 2004 - 5:26 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
you might not have the factory amp since you appear to have the baseline stereo
post Apr 26, 2004 - 9:19 PM
hermo69
Joined Dec 7, '03
From CANADA
Thanks for the help guys......i put in my CD player and guess what...............
NO AMP!!! Install was about 10x easier than expected......i took my CD player outta my tercel and kept the wiring harness......just like windows.....plug n play!
Lo-Fi Version Time is now: November 28th, 2024 - 10:18 PM
