Oil and temp gauges, install questions |
Apr 26, 2004 - 2:33 PM |
Enthusiast Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
I have an oil pressure gauge, and a water tempurature gauge, both mechanical, and i was wondering exactly how you install them. For the oil pressure, from what i read and searched, i find the sending unit, and use a t-fitting off of it. Where exactly is this? ive read that it is near the exhaust manifold (5SFE) but im not sure exactly. Also, where do i run the water temp sensor to?
Thanks -mike Edit: another Q, with the oil pressure line, it says to slide the hex nut on the nylon tubing, then a ferrule, and then tighten the nut onto the engine fitting... it seems like the tubing would want to just slide out (especially if it is under pressure) will tightening down the nut keep the tubing secure to the fitting? This post has been edited by mikew04: Apr 26, 2004 - 4:52 PM -------------------- |
Apr 26, 2004 - 9:42 PM |
Enthusiast Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
the water trmp sensor and get installed in some water neck in/outlet. oil pressure comes from the oil sending unit, T' in there, on the 7a its located on the lower left side of the block
Apr 27, 2004 - 9:30 AM |
Where is the oil sending unit located on the 5s? And do i have to drill and tap the temp sensor into an outlet, or is there somewhere where i can just screw it in?
thanks -------------------- |
Apr 28, 2004 - 1:04 PM |
Anyone?
Apr 28, 2004 - 2:28 PM |
Enthusiast Joined Jan 22, '04 From bellingham, WA Currently Offline Reputation: 0 (0%) |
i'd have to look for it to find it... but on an A series motor it's located on the exhaust side (when looking at exhaust side) on the left.... right in the middle of the block..... the oil sensor is roundish in shape and goes into what i believe is a 1/4" hole
Apr 28, 2004 - 6:39 PM |
Is the sensor going to be an electric plug?
thats all i can find any help would be great, never installed gauges thanks! -------------------- |
Apr 28, 2004 - 10:44 PM |
for the temp, u have to remove the neck, drill and tap the hole u made to size. use some teflon to seal it up when u thread in the sensor. no biggie.. |
Apr 29, 2004 - 1:08 AM |
Enthusiast Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
mike, thats correct as far as how to connect that line. what happens is when you tighten the nut, it smashes down on the ferrule which mushrooms and seals. There usually only good for one tightning. Dont use teflon, use a little bit of silcone
both on the t and the gauge. Im getting ready to hook up my gauges too. If worse comes to worse as far as water goes, get a small piece of pipe(alum or stainless) same od as id of hose, weld a not for your sending unit, and cut the hose and put the pipe in between there. this will now be your temp sender reader. You can also t a t to get an extra line for both oil pressure and oil temp. Hope this helps |
Apr 29, 2004 - 4:52 PM |
Thanks for the info
What does the oil sending unit look like? thanks -------------------- |
Lo-Fi Version | Time is now: December 4th, 2024 - 5:01 PM |
