Removing interior door panel stuck at manual roll |
Apr 26, 2004 - 4:11 PM |
Enthusiast Joined Jun 2, '03 From Annandale VA Currently Offline Reputation: 0 (0%) |
I am tryna install power windows into my celi, I cant get the door panel off on the inside im stuck at the manual window crank I cant seem to get it off... anyone know the trick?
Apr 26, 2004 - 4:15 PM |
Enthusiast Joined Sep 27, '02 From UK Currently Offline Reputation: 1 (100%) |
Not sure but a thought...
Does it have a circlip at the back of the handle? |
Apr 26, 2004 - 4:16 PM |
There's a little pop-in clip that clips around the window crank...You can see the ends of it if you push the door panel back a bit and then turn the window crank. Once you can see the ends of it, pop them off with a flathead screwdriver, and then the crank comes off.
Apr 26, 2004 - 4:19 PM |
Thank you coomer!!! I knew you would know glad you where online!! I was startin to get really stuck.
Apr 26, 2004 - 4:22 PM |
Glad I could help. I'm just at work, taking a break from the real work that I'm supposed to be doing for the company. -------------------- New Toyota project coming soon...
Apr 26, 2004 - 4:58 PM |
Thought it was that...6g Celica speciality!
The seat adjusting knobs use the same clip mechanism. |
Apr 26, 2004 - 5:20 PM |
Yep...I was thinking about that too when I was writing my first post. I had to buy the new knob and had trouble with that clip. -------------------- New Toyota project coming soon...
Apr 26, 2004 - 5:26 PM |
Yer, I seem to remember when I was doing my interior that those seat knob clips were an absolute bug*er to get to and remove.
Lo-Fi Version | Time is now: November 25th, 2024 - 12:26 PM |
