pulling wires from door inside? |
Apr 26, 2004 - 9:14 PM |
Enthusiast Joined Jun 2, '03 From Annandale VA Currently Offline Reputation: 0 (0%) |
Anyone pulled the wire from the inside of the door to the inside of the car? Im trying to wire power windows still, annddd the black tube doesnt cooperate, whats the trick anyone know?
Apr 27, 2004 - 6:56 AM |
Enthusiast Joined Sep 27, '02 From UK Currently Offline Reputation: 1 (100%) |
Metal coat hanger unwound and threaded carefully through,
Make a little hook at the end of the coat hanger wire, Attach wire and gently pull through. Hey Presto! |
Apr 27, 2004 - 7:15 AM |
Enthusiast Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
15 inch zip ties and some pam.
-------------------- All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Apr 27, 2004 - 7:18 AM |
Enthusiast Joined Feb 23, '03 From Florida Currently Offline Reputation: 0 (0%) |
Screw the pam, use KY =) |
Apr 27, 2004 - 9:15 AM |
Enthusiast Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
I USED A THICK ZIPTIE. oNCE I GOT IT IN, I TAPED THE WIRES I NEDDED TO IT AND PULLED THEM IN. YOUR SORT OF WANT TO MOVE THE RUBBER BOOT WITH YOUR HAND TO GIVE IT MORE OF A STRAIGHT SHAPE.
Apr 27, 2004 - 1:27 PM |
Enthusiast Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
I just ran the wire outside of the boot.. When I put the rest of my system in this summer I will run the rest of the wires outside of it, and then wrap it and the existing boot in electrical tape.
Apr 27, 2004 - 3:45 PM |
Enthusiast Joined Dec 1, '02 From Pittsburgh, PA Currently Offline Reputation: 0 (0%) |
Please heed my words as I found out this info the VERY HARD way.
Toyota, in all their anal-retentiveness to tidy thigs up, TAPED the ends of the boots. This means that unless you undo all that tape there is no way you are running wires from the door THROUGH the boot and into the car. Here's what I did, and it takes a little effort but it allows you to do what you want: What you'll have to do is pull the boot out of each side - you might want to do one side at a time. With your door WIDE open, stick your hand in there by the hinge and work one end of the rubber boot out of it's hole. Once you have it out, you'll want to get in there with a razorblade and gently cut the electrical tape (or whatever they used) until you're able to remove all the tape. This might take some time and effort as you don't have much room to work with. Repeat this procedure for the other end of the boot. Once you have this accomplished, it's just a matter of pushing the boot back in the holes - remember, it actually seats into a slot on each side. After that's done just tape a piece of wire coat hanger to the end of your wire(s) and feed through. Like I said, this will take some time but having the information I just gave you will make it SOOO much easier. Good luck! |
Apr 27, 2004 - 9:24 PM |
*grins* just finished, yeah that boot is a pain! I got advice from doggy too, seemed to work, maaann its hard guys!
Lo-Fi Version | Time is now: November 28th, 2024 - 9:01 PM |
