> 8-Speaker System Upgrades
post Apr 27, 2004 - 9:05 PM
Element
Joined Apr 16, '04
From Raleigh, NC
Just got my Celica a little while ago and I'm gonna start upgrading my system...starting with a Pioneer DEH-P4600MP receiver, eventually an amp and 2 12" subs and a box for the trunk...anyway, I was wondering if anyone had some recommendations on other stuff. Plus, I'm unsure what I'm gonna need to do with the 2 amps I already have in the car since I have the premium system...I'm unsure about whether I need them or not, etc...any help would be appreciated!
P.S. I just turned 18, pay my own insurance, gas etc., and I work at a grocery store, so funds are limited...sadly enough...
This post has been edited by Element: Apr 27, 2004 - 9:06 PM
post Apr 27, 2004 - 9:37 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
Heres what I plan on doing
I plan on running a set of 6.5" components (low spot and tweeter spot), and 4 inchers (mid spot) off the head unit, that takes care of the doors.
then I plan on buying a 2 way amp for two rear 6.5's, and then a 2 way amp for two 12"s for the trunk.
Running all my own wire.
Utilizing all spots made available to me by having the 8 speaker stereo upgrade, and bypassing all the factory garbage that isnt worth dick in the aftermarket sound area smile.gif
post Apr 27, 2004 - 10:48 PM
celimanST
Joined Nov 15, '03
From mississippi
Well I am going with:
Alpine 9833 head unit, crystal 6.5 coaxials in the rear, crystal 6.5 components in the front ran by 400w 2ch amp, two 8" kick subs in the doors ran by a 400w 2ch amp, 4 crystal 10 subs ran by two 1200w 2ch amps, two capacitors, Alpine cd changer, viper alarm and if I can find one a high output alternator.
I may also get a audio control line drives later.
I hope this gives you some ideas.
If you need equipment check out this POST
William
post Apr 30, 2004 - 12:54 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
celiman , if I were you I wouldnt put two 8" kick subs in the doors
allso how are you planning on fitting a 6.5 inch component in a 4 inch speaker spot?
With four 10's I think you will have enough bass anyway you dont need 8 inch kickers.
You dont want your bass to over power the other elements all that much, cause then all you will hear is thumping and not the actual music
post Apr 30, 2004 - 1:06 PM
shid
Joined Jan 8, '04
From LA
4 inch speaker spot? I hope you mean the door midrange!!! The back is 6.75.
post Apr 30, 2004 - 3:15 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
QUOTE (shid @ Apr 30, 2004 - 6:06 PM)
yes I meant the midrange spot in the doors, thats built for a 4 inch speaker i believe, and iwondered how he was gonna get 6.5 inch components in there smile.gif
post May 1, 2004 - 2:41 AM
celimanST
Joined Nov 15, '03
From mississippi
Here is my plan:
I will be hooking my amps up to switches, and as far as the 8s are concerned they will be on switches as well that way I can turn them on when needed. The reason for all the bass is competion SPL.
William
post May 1, 2004 - 2:42 AM
celimanST
Joined Nov 15, '03
From mississippi
Here is my plan:
William
post May 1, 2004 - 2:43 AM
celimanST
Joined Nov 15, '03
From mississippi
I don't know why it posted twice
post May 1, 2004 - 8:01 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
but that doesnt show how you are getting 8 inchers and 6.5 inchersi n the door
post May 1, 2004 - 10:40 PM
celimanST
Joined Nov 15, '03
From mississippi
8" in doors how-to
post May 2, 2004 - 12:24 AM
shid
Joined Jan 8, '04
From LA
He's expressing himself badly.
How are you going to fit the 6.5 components in the 4 inch midrange spot?
post May 2, 2004 - 2:14 AM
celimanST
Joined Nov 15, '03
From mississippi
I not going to use that spot in the doors. I am going to make custom kick panels for the 6.5s. Is that better???
William
post May 2, 2004 - 11:42 AM
shid
Joined Jan 8, '04
From LA
Sure, I'm sure he was just curious
Lo-Fi Version Time is now: November 23rd, 2024 - 8:59 PM
