> Has this happened to you
post Apr 28, 2004 - 2:19 PM
macavely
Joined Nov 4, '02
well this has happened to me twice already.. with the temp. out side is nice and warm and then drops in the middle of the night.. when i get out of work to start my car.. it fires just fine but doesn't hold idle.. then cuts off.. so i'll just idle it my self for 30 seconds and the put it in 1st and take off.. once in gear and driving when i come to a stop she idles just fine again..
just wanted to know if this has happened to anyone else?
post Apr 28, 2004 - 2:21 PM
That doesn't happen to me...I don't know what would be causing that problem for you.
post Apr 28, 2004 - 2:24 PM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
sounds like the cold start sensor isn't too happy..... if it's bad, lol, i have a 4a-fe one that works just fine.
on a 4a-fe it's located on the frontside of the intake manifold (facing you when you open the hood)... has 2 bolts holding it in....
macavely
Joined Nov 4, '02
yea i have not clue were to starty looking.. i'll try checking the TB this weekend.. there might be condisation at night then its getting frozen..
post Apr 28, 2004 - 2:25 PM
macavely
Joined Nov 4, '02
QUOTE (toyotaspeed_90 @ Apr 28, 2004 - 2:24 PM)
thanks i'm going to have to check that out too...
but wouldn't i get a CEL if there was something worng with that sensor?
post Apr 28, 2004 - 6:35 PM
mofu04
Joined Jan 19, '03
From South Jersey
Actually, I've been suffering the same symptoms with my car Mac. If you find a way to fix it, be sure to post about it.
Donald
post Apr 28, 2004 - 8:29 PM
same problem here
when its hot the car has trouble starting. it will turnover but want to die right away. lately on hotter days it dies as soon as i let off the gas....then after a few seconds of holding the gas it will get back to normal and have no problems.
post Apr 28, 2004 - 8:54 PM
macavely
Joined Nov 4, '02
i wonder if this just a 5sfe problem?
post Apr 28, 2004 - 9:00 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
i have the same problem - GT as well
I thought just to adjust my idle a bit up, cause on super warm days it'll have trouble staying alive after sitting for a while. It does a flux in the tach of about 200. Most i've seen it go is an idle at 650. WAY TO LOW FOR ME!
post Apr 28, 2004 - 9:51 PM
lazzyboy121
Joined Feb 17, '04
From michigan
same here........and ofcoarse it a GT
94 celica GT
92 honda prelude si<h22 swap>
93 eagle talon TSI <4G63 powered>i wish it was AWD
90 mitsu eclipse GSX<4G63 powered>SOLD
LEXUS IS300< im looking for one!
Lo-Fi Version Time is now: November 28th, 2024 - 8:31 AM
